Small car, large alternator - Car Audio Classifieds!
Old 05-10-2013, 12:15 PM
whos that's Avatar
0/11 sssss1635
Default Small car, large alternator
Sick of only 14 mpg on the highway, so I'm buying a honda.
To small of a car for a large battery bank, don't want my ass an inch off the ground.
So, how bad will a 200-250 amp alternator bog down a little 4 banger?
I would rather not do 0-60 in ten seconds and 20 mpg
Old 05-10-2013, 12:24 PM
Mr.G6's Avatar
0/11 sssss4614
with dual alts on my old civic ( d15b7) AND hauling around roughly 500lbs in gear still got 35mpg
a single alternator i noticed no difference at all... when i removed the box and batteries i got my 40mpg back
2000 Gmc Sonoma ext cab
Old 05-10-2013, 12:44 PM
mega fatty
0/11 sssss6008
I had 5 batts and a 14cf wall in my escort bringing it down to 28 average from 32
That was a 170a alt
07 mazdaspeed3
rd d9 @ .5ohm
Old 05-10-2013, 02:05 PM
whos that's Avatar
0/11 sssss1635
Thanks for the replies, but how can you guys drive with 500+ lbs in a 3500 lb car?
That's gotta ride like shit
Old 05-10-2013, 02:08 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
For the love of bass people are willing to do anything. Thatd be like saying, why ruin your car by putting all dem der bass speakers in dat der boom box right behind ur durn head?
It's better to keep your mouth shut and give the impression that you're stupid, than to open it, and remove all doubt.
Mistakes are how you learn; try not to learn too much at any one time.
Old 05-10-2013, 02:16 PM
whos that's Avatar
0/11 sssss1635
Tearing up the interior is one thing...
I'm not willing to sacrifice suspension and drivability though... No point in having a badass system when you can barely drive because your rear springs are shot
Old 05-10-2013, 02:26 PM
0/11 ssssss579
The alt itself shouldn't bog down the engine at all during normal operation. When you have your music up and the alt is working it will be noticeable though, especially at idle.
Old 05-10-2013, 02:35 PM
art1618's Avatar
CACO SUPPORTER
0/11 sssss3165
you'll see rpm drop and a little shake from the engine if alt is big enough, im going dual on the yaris. i carried about 400lbs of shit moving furniture, boxes said the weight on there and added up a little over 400 and the car still did fine. car is about 2000-2200 empty no seats get 31 mpg cause i drive like an ass.
1.5l 4 banger.
however the weight did drop it a quite a bit about 3" from the ground where its normally around 5" and if you have to swerve abit because some jackass cuts you off the weight tranfer laterally sucks and could be dangerous. need to buy coilovers/bags to adjust the preload to keep the weight up and the car at a certain height.
Old 05-10-2013, 02:52 PM
0/11 ssssss892
In my 87 crx i have always run the stock alt with no problems up to 7k watts and 18volts anything over 4k watts i just used one of these.
http://www.ebay.com/itm/111066321247...84.m1560.l2649
Old 05-10-2013, 02:58 PM
0/11 ssssss386
I drive th my 94 accord daily..and it has 500 lbs of audio gear and a mechman alt. My ass end is about 3 inches from the ground. I drive the speed limit and go slow over speed bumps and don't have too many issues. I don't think it really rides too bad, but I am getting new rear springs to raise my ass back up to stock...more because of the looks. And the alternator is no big deal in my mpg. But my biggest complaint is the weak ass belt wrap and under a heavy load the belt will slip and squeal.
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Any way to replace a small case with a large case on a gm? westman995 General Car Audio Discussion & Questions 2 01-13-2013 04:13 PM
Multiple small batteries vs. Large batteries thawaxshop General Car Audio Discussion & Questions 17 09-01-2012 09:42 PM
Large Lot of Car Audio - Package Deal or Seperate! Take a look! extreme Car Audio Packages 13 12-05-2010 01:35 PM
WTT: Tons of car audio for large mono & 4ch extreme Car Audio Trader (WTT) 1 08-26-2010 09:37 PM
