when u do a recone can you change ohm's? - Car Audio Classifieds!
Old 05-10-2013, 06:42 PM
0/11 ssssss358
Default when u do a recone can you change ohm's?
found some dual 1 american bass hd12's that need to be reconed...if i get them for a good deal can i change them to dual 2ohm coils?i did a search and couldnt find an anwser.
dodge 1ton dually with 8 12's and 4 vfl 1100.1's....Cummins powered with quad alts and 35 batteries.my build log below. 162.0 at 42hz burp and 160.2 in streetbeat so far ..and is a demo machine!!
Old 05-10-2013, 06:45 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Yep yep. Some people recone perfectly good subs specifically for an ohm load change.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 05-10-2013, 07:11 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Some will be a lil different spec wise if the motor was optimized for a specific ohm.. so if it was d2 optimized, then a d1 optimized motor would be slightly different if u swapped the coils between (the specs would be diff then a similar motor)
So d2 optimized with a d1 coil wouldn't be the same specs as the same motor in a d1 optimized (if that makes sense)
For ur motor, wont matter though
Old 05-11-2013, 12:08 AM
Matt3824's Avatar
0/11 sssss3754
I believe the AB HD motors are slightly different between D1 and D2 actually.
Old 05-11-2013, 01:58 AM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
I remember the original BTLs were built that way as well, but the difference was so small that it didnt matter
Old 05-11-2013, 02:05 AM
0/11 ssssss285
If its a dual one now then dual two should fit as the OD would be smaller. If it was a dual 1 and the gap was optimized for a dual two then the dual one may not fit due to gap clearances.
Old 05-11-2013, 04:35 AM
4/11 ssss31258
you assume a lot in your statement here.
what you said, could only be true if the exact same former and material was used to make both coils.
but
most manufacturers only make one size gap for a subwoofer series and they use it universally regardless of impedance or diameter. {D2, D1, D 1/2.... get the same motor gap}
Old 05-11-2013, 04:41 AM
0/11 ssssss285
That's why I stated if it was optimized for a two ohm coil. I highly doubt a different sized former would be used. Wouldn't make logical sense to tool different bodys
Old 05-11-2013, 04:48 AM
4/11 ssss31258
That's why I stated if it was optimized for a two ohm coil. I highly doubt a different sized former would be used. Wouldn't make logical sense to tool different bodies
I mentioned the former because aftermarket coils might not have the same former as original coils.
I agree it doesn't make logical sense, but in the case of AudioQue, that's exactly what they did on some of the HDC3 subs.
Old 05-11-2013, 04:53 AM
0/11 ssssss285
Yea, that would need to be taken into consideration if the parts were 3rd party.
Does Hz change r1 banshee General Car Audio Discussion & Questions 13 06-26-2012 12:28 AM
Need a 4k+ amp at 2 ohm's... krunchbubble Wanting to Buy (WTB) 5 04-26-2011 07:35 PM
Change of plans! Need a recone for a ver.1 sundown nightshade rachidfunaki (Fix My Speaker) 7 03-30-2010 12:50 AM
Ohm's law help Andrew General Car Audio Discussion & Questions 5 05-22-2009 11:43 AM
18" Fi Q Dual 2 Ohm's Sub BryanCain 18" Subwoofers 5 11-16-2008 09:08 PM
