POO!!!! External reg? - Car Audio Classifieds!
Old 05-11-2013, 10:50 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
Default POO!!!! External reg?
my regulator sparked when i hooked the field wire up from the alt and then got hot/warm.....i have pos but no ground on it could that be the issue? im afraid to try anything really lol
Old 05-11-2013, 11:29 AM
Mr.G6's Avatar
0/11 sssss4614
How to wire up Excessive Amperage 911-02R adjustable voltage regulator and 5 pin relay - YouTube
2000 Gmc Sonoma ext cab
Mr.G6's Avatar
0/11 sssss4614
watch that video
Old 05-11-2013, 06:38 PM
hawaiianmaxx's Avatar
0/11 ssssss862
Shouldn't your ground be the first electrical connection made?
KIDS SAY THE DARNDEST THINGS-
STOP PAYING ATTENTION TO YOUR RATIO IN 4TH ORDERS!!!! Ratios in 4th orders mean about as much of the color of socks you wear.
I never said getting 60 MUSICALLY will be easy did I? Getting 60+ on a burp machine is, sorry to say that but it is.
Old 05-11-2013, 07:37 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
it probably is grounded if it is sitting on something metal.. And check voltage going in and coming out. If both are within acceptable parameters then it is fine. And regulators do run warm. (hence the massive heat sink)
Current Build:
#60sHereIcome
The OFFICIAL post pics of your poo thread. 92K1500 Uncensored Off Topic 301 06-22-2014 01:02 PM
mae 250 amp 16v external reg alt! mads10bass Wiring, Electrical & Other Installation Equipment 32 04-17-2011 07:43 PM
external reg help spl-101 General Car Audio Discussion & Questions 10 10-21-2010 12:02 PM
holy poo F3M4 Off Topic Chat 38 10-09-2009 12:24 PM
high amp ford 3g alt 225 amp with external reg Old/School Wiring, Electrical & Other Installation Equipment 1 08-04-2008 04:57 AM
