simple amp repair? - Car Audio Classifieds!
Old 05-11-2013, 10:49 PM
jheist1991's Avatar
0/11 sssss1070
Default simple amp repair?
So I got a Planet Audio BB2400 from a friend for free, he just didn't want to mess with fixing it. The problem is, it needs the rca's replaced. I've got the new part here, but where I'm stuck is how to remove the board from the case. As far as I can tell, that's the only way to replace the part, since there's 6 spots that have to be soldered in about a 1 square inch area.
Has anyone ever repaired the rca's on an amp? I was told that it would be a pretty easy fix so I figured I'd have a go at it myself. I'm just stuck on how to get the board out without damage, since I'm not seeing any mounting screws or anything.
Old 05-11-2013, 11:06 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Ud have to unscrew all the gets, keeping track of the isolators behind them (little plastic sheets) then any other screws and end caps that need to be taken out that hold the board down...then u can pull the board...de-solder and re-solder the new rca... get some new dielectric grease (the white crap behind the gets that gets everywhere) they sell it at radio shack, apply a lil new grease... and do everything u did to remove it, but backwards...the sheets behind the gets is very important that there not lost or placed to allow the fet to touch
Encase ur unsure, this is a fet
Old 05-11-2013, 11:15 PM
Authorized Vendor
0/11 ssss14115
That board may be a slide out design once the fets are free
Old 05-11-2013, 11:17 PM
jheist1991's Avatar
0/11 sssss1070
Thanks jeff! The only thing I'm not getting is the fets part. I'm not seeing any screws or anything holding them down, just a metal piece over them that kinda pinches them in place. I can get a pic but it'll take a minute.
Old 05-11-2013, 11:20 PM
Authorized Vendor
0/11 ssss14115
There clips
How to easily remove Mosfet Spring clips Tutorial - YouTube
Old 05-11-2013, 11:27 PM
jheist1991's Avatar
0/11 sssss1070
Ok I feel like at this point, I should be getting mildly nervous. I've gotten a portion of the clips off, revealing 10 fets, and not one thing holding them in, no screw, bolt anything.
Old 05-11-2013, 11:31 PM
Authorized Vendor
0/11 ssss14115
Might be a slight bit of glue behind them...what ever u do, Do NOT pinch the fets with pliers and such.. there brittle
Old 05-11-2013, 11:35 PM
0/11 sssss2429
Feedback Score: 46 reviews
The fets will adhere to the thermal pad, you will have pry them away from the heatsink.
There us also a couple screws holding the board in, don't forget the gnd wire also.
Old 05-11-2013, 11:36 PM
jheist1991's Avatar
0/11 sssss1070
Yep, nothing there. No screws, no glue, nothing. Just the white grease and slip behind them. Oh and now I understand why these amps are so cheap lol. Using the codder pin tool like in the vid, I'v already had 2 of the clips start to crack around the hole with almost no pressure.
In all honesty, this is starting to seem like more work than it's worth, but now I'm too far in to stop lol
Old 05-11-2013, 11:38 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
The fets are held by the clips and dielectric compound. Pry them up and slide the board out... on those amps the board actually isn't anchored to the heat sink. I just took two apart last week lol
Sent from my SCH-I605 using Tapatalk 2
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Amp repair help tymoto21 General Car Audio Discussion & Questions 42 01-23-2012 10:45 PM
Amp repair help please thekernal123 General Car Audio Discussion & Questions 1 12-01-2011 02:57 PM
simple component/amp comparison fyerbyrd22 General Car Audio Discussion & Questions 9 08-07-2010 08:23 PM
amp repair Rd4me General Car Audio Discussion & Questions 9 11-18-2009 04:17 PM
