Should I build a t-line for my SA-12 tomorrow? - Car Audio Classifieds!
Old 05-12-2013, 01:24 PM
Burkem_10's Avatar
0/11 ssssss469
Default Should I build a t-line for my SA-12 tomorrow?
I'm doing all sorts of wood working this weekend. Today I'm building a few things for my apartment and tomorrow I was planning on building a t-line for my SA-12.
I found that my max dimensions are 33w x 28d, sketched up a quick t-line and found that the port length would be ~102" which would work, and get me to a 33hz tuning. Well, I had some spare time so I added 45s to the sketchup, re-measured, and now I'm only seeing 80-82 inches which would be about 6.75 feet or 41hz.
The fs of the SA-12 is around 33hz IIRC and I don't know if it's a good idea to build this box now... I'm going for SQL rather than pure SQ so 41hz doesn't sound too optimal to me. However, I have been dieing to try out a t-line... What would you guys do?
04 GP - SQL-ish
X-12 in a trunk wall
JBL GTO1400
Cadence ZRS-C9
HAT Imagine 6.5s active
Rockford Fosgate 360.3
Old 05-12-2013, 01:30 PM
mine is closer to 50hz and still plays low enough to interest me. The higher tuning is better for sq, not worse.
Old 05-12-2013, 01:32 PM
Burkem_10's Avatar
0/11 ssssss469
Interesting... I google'd quite a bit before I decided to ask here and I was catching the drift that they didn't play very far below tuning. I'll count you as a 'yes' then lol. I really want to build this bish.
04 GP - SQL-ish
JBL GTO1400
Cadence ZRS-C9
Old 05-12-2013, 01:35 PM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Huh?
usually the lower the tuning the better SQ, higher tuning is for the meter
2005 Buick LaCrosse
HU: Alpine INE-S920HD
you could try tapering try 2:1 ratio with the small end being the "port" opening. it will lower the -3 freq response down a good bit by compressing the wave. It will lose a little efficiency but will still be over ported and will sound 10 times as nice.
Originally Posted by Raptor660 View Post
Huh?
not even close.
Old 05-12-2013, 01:37 PM
Ridnclean is actually running one of my tapered tlines right now as well. it's a no wall set up for 2 18" mt's in his silverado.
Old 05-12-2013, 01:43 PM
Burkem_10's Avatar
0/11 ssssss469
Yeah, I'll have to look into tapering. My current setup is a sa-12 in a fourth on ~1,200w. 1 cube at 55hz and 2 sealed. It doesn't quite have enough output on the low end which is why I'm switching things up.
04 GP - SQL-ish
JBL GTO1400
Cadence ZRS-C9
Old 05-12-2013, 01:57 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
So your sealed section is 2x as large as the ported? Your ported side should be larger than the sealed side unless you just typed that wrong.
Old 05-12-2013, 02:02 PM
Burkem_10's Avatar
0/11 ssssss469
No, that's correct. I wanted a flat response and wide bandwidth and that's what we came up with.
04 GP - SQL-ish
JBL GTO1400
Cadence ZRS-C9
Old 05-12-2013, 02:43 PM
Burkem_10's Avatar
0/11 ssssss469
I've been told no elsewhere... Hmm, I don't know what to do
04 GP - SQL-ish
JBL GTO1400
Cadence ZRS-C9
Box Question 4 Build Tomorrow damwhite General Car Audio Discussion & Questions 0 04-07-2013 10:49 PM
box design - need fast - build tomorrow arejayeye Enclosure Discussion & Design Construction Help 12 08-03-2012 01:59 AM
sqoverspl's Transmission Line Build sqoverspl Build Logs 18 11-16-2010 10:53 PM
8" T-line build SPY Off Topic Chat 21 02-28-2010 01:01 AM
Sundown e8 T-line build SPY Off Topic Chat 21 02-13-2009 06:57 PM
