Pair of SA-10s in 4th order... fail so far... - Car Audio Classifieds!
Old 05-12-2013, 10:55 PM
n8skow's Avatar
0/11 sssss1519
Default Pair of SA-10s in 4th order... fail so far...
So I built a 4th order for a couple woofers last summer, and it kinda fell on it's face, so I shelved it for a rainy day when I could mess around with it some more...
Well, the rain has come and gone a few times... and I got my hands on a couple more-4th-order friendly SA-10s.
Currently, sealed side is 0.9 cubes, ported side is 3.8 cubes (before woofer and port displacement) - About 3.33 cubes after displacements. Port area is 60 square inches.
I've got a DATS, and ran a impedance sweep with the port closed off
Looks like about 49/50hz for the peak.
Removed my port plug, and ran the sweep again:
Looks like the dip is right at 51hz...
I'm dumping quite a bit of power into this thing - and the results are still pretty blah though... thoughts?
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
Old 05-12-2013, 10:57 PM
twizt3dfuc's Avatar
TEAM FSMD FOUNDER
0/11 sssss1372
I think your ported chamber is too big.
Sent from my SCH-I605 using Tapatalk 2
TEAM DURTY POWA!!!
Compounding Pharmacy Extraordinaire
My Cream Makes You Stop Hurting
Old 05-12-2013, 11:41 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Switch to .85 after displacement for sealed , 2.125 ported per sub after all displacements... try 75 sq inch of port tuned to 56
Old 05-13-2013, 02:46 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Wait... you're running "sealed" resonance by plugging the bandpass' port? So... the subs are like completely enclosed? What's that going to tell you? And resonance is the low spot dip AFTER the peak.
The bandpass alignment's resonance/tuning is 51hz, looks like.
What do you mean by, "the results are pretty blah"? Is it peaky or the output isn't there or what?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 05-13-2013, 02:54 AM
I'm wondering the same thing.
Old 05-13-2013, 02:53 PM
n8skow's Avatar
0/11 sssss1519
If my math is right - it's 1:3.6. Isn't a 1:3 pretty ideal?
Old 05-13-2013, 02:54 PM
n8skow's Avatar
0/11 sssss1519
56 sounds awefully high... I plotted for 47hz in WinISD - which told me about 0.9 cubes for the sealed side...
.85 for sealed, per sub - or combined?
I take it you've done one for the SA-10s? Sounded good?
Old 05-13-2013, 02:57 PM
n8skow's Avatar
0/11 sssss1519
Aren't those Hackmunch's instructions to find the sealed resonance? I may of misunderstood...
The low dip after the peak appears to be 80ish...?
The results being blah are the output - struggles to break a 141db on 1300 watts.
Old 05-13-2013, 03:02 PM
tacomaguy1's Avatar
0/11 sssss4401
He says to play it without the port or loading wall in. Can't just plug the port
I think
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 05-13-2013, 03:04 PM
Authorized Vendor
0/11 ssss14115
56 hz isn't high for those subs in that size for there compliance... .85 per sub after displacements ... I have a "knack" for bandpass..its all I build
The Following 2 Users Say Thank You to Jeffhulbert50 For This Useful Post:
doug118 (05-14-2013), n8skow (05-13-2013)
8 XD 10s In A 4th Order Doing DAMAGE!! got160s? Car Audio Videos 0 10-10-2012 05:54 PM
4th order for 4 sa 10s littleharv93 (Sundown Audio) 6 08-16-2012 01:44 PM
4th order for 4 l7 10s jorgesau100 Enclosure Discussion & Design Construction Help 0 03-27-2012 12:40 AM
4th order for 6 sa 10s 99Bonney Enclosure Discussion & Design Construction Help 12 07-18-2011 08:26 PM
2 4th Order 10s D4 GearGuy2001 Wanting to Buy (WTB) 10 07-05-2010 08:31 AM
