jbl crown a6000 gti - Car Audio Classifieds!
Old 05-13-2013, 03:13 PM
209native's Avatar
0/11 sssss1975
Default jbl crown a6000 gti
hey guys just tryn to get some opinions on this amp.specs say 6k @1-4 ohm @12 volts and [email protected] 14.4 volts any input would be great
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 05-13-2013, 04:03 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Beast amp and becoming rare. Well worth the money.
Old 05-14-2013, 09:36 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
JBL Crown 6000GTi ~ A6000GTi over 8k watts @ 4 ohm
I would say a dam good amp. These things are huge in person....I think Alma Gates used them. So you know if the Queen of SPL used them, they gotta be good.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-14-2013, 09:40 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Be aware they are very different amps. It has 2 high voltage rails that when in parallel can put out 320VAC. Nothing to play with. Also they make more power at higher ohm loads. Its an odd amp to wire up so make sure you know what you are doing.
0/11 sssss1417
7.5k at 4 ohms.. what else do you need to know
Old 05-14-2013, 09:44 AM
0/11 ssss12531
Almost identical to JL Audio amps...no matter what impedance you give it, it's the same wattage....which I'm baffled about.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-14-2013, 09:53 AM
Ja Marcus
0/11 sssss6975
^Actually that is not entirely correct. They make more power at 4 ohm then they do at 1 ohm. Its something like 7k at 4 ohm and 6k at 1 ohm.
Old 05-14-2013, 09:58 AM
0/11 ssssss546
Nothing
Old 05-14-2013, 10:01 AM
209native's Avatar
0/11 sssss1975
thanks for the input guys im waiting to hear back from the guy. he says its in for repairs but will be for sale when he gets it back witch make me a little leary
prs 80 hu
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 05-14-2013, 10:03 AM
0/11 ssssss546
Stolen...
Very unusual looking, yet so pretty to look at...
2008 Silverado 16 dd 500 series 12s on a jbl gti crown 6000 dwhite Uninterrupted Build Logs 2 03-18-2013 11:13 PM
Jbl Gti 15 jonree4483 15" Subwoofers 15 12-13-2011 06:28 AM
FS JBL Crown gti a6000 $1300 tahoefixssd Mono Amplifiers 8 06-29-2011 01:20 PM
crown a6000 gti oldschool General Car Audio Discussion & Questions 31 04-01-2011 12:16 PM
