Please verify my RCA ground job - Car Audio Classifieds!
Old 05-14-2013, 02:04 PM
Burkem_10's Avatar
0/11 ssssss469
Default Please verify my RCA ground job
Googling didn't answer my question so here I am. I am only using the top and bottom set of RCAs, is it okay that I'm grounding the middle ones as well?
Kind of a stupid question but I just want to be 100% sure before I reinstall this.
04 GP - SQL-ish
X-12 in a trunk wall
JBL GTO1400
Cadence ZRS-C9
HAT Imagine 6.5s active
Rockford Fosgate 360.3
Old 05-14-2013, 02:05 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
you did good now try it b4 u install it and make sure it works
Old 05-14-2013, 03:11 PM
0/11 sssssss29
Looks good to me. I usually like to splice the shield of the rcas though... I guess personal preference?
Old 05-14-2013, 03:21 PM
0/11 sssss4519
I usually solder the wire to the RCA shield.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 05-14-2013, 06:48 PM
0/11 sssssss29
Soldering is Feinstein going to get you the est possible connection if you're good and careful not to burn the rest of the cable.
If you're not, you can do a similar way of what you did, by stripping back the smallest amount of jacket on each of the RCA cables and do single tight loops around each opening to the shielding, and finishing with e tape and some zip ties to secure it.
Old 05-14-2013, 11:00 PM
QmarcesQ's Avatar
0/11 ssssss124
Why do you ground the rca? is that just for headunits? i have never heard of doing this for amps/
Old 05-14-2013, 11:07 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
or you could simply open up the unit find the blown pico fue on the board and solder a jumper like i did on ym AVH4200...
SHABAM
Old 05-15-2013, 12:30 AM
Search for "pioneer pico fuse noise" or something like that and you'll get your answers. In short: there's a fuse between the signal ground and chassis ground inside the headunit. It's prone to blow, and without that connection the signal ground differential between the headunit and amp will be different, inducing noise.
OP that looks fine.
Old 05-15-2013, 12:37 AM
DonH's Avatar
0/11 sssss6645
pico fuse is located on the board where the harness input is on the left of it. will have FU321 a "p" and a white box around it. chk if it burnt to shit.
SHABAM
Chassis ground vs. running ground wires Wingman0121 General Car Audio Discussion & Questions 1 06-19-2012 07:14 PM
Please verify my box specs ThisGuy31 Enclosure Discussion & Design Construction Help 0 04-29-2012 02:04 PM
Scosche 25ft. 2-Channel RCA & Scosche RCA Splitters nicholask1993 Wiring, Electrical & Other Installation Equipment 4 01-25-2012 09:20 PM
4 guage wire, rca, ground terminal caloriu Wiring, Electrical & Other Installation Equipment 6 06-25-2011 02:29 PM
chassis ground = horrible ground loop? nicyousuckk General Car Audio Discussion & Questions 4 03-01-2011 11:32 AM
