Sundown Z v.2 15 Metal Clang Noise - Car Audio Classifieds!
Old 05-14-2013, 10:35 PM
0/11 ssssssss5
Default Sundown Z v.2 15 Metal Clang Noise
Hello everyone, I'm new to the forums at CACO!
But to my problem:
I have a Sundown Z v.2 15 I got from a buddy who thinks it's broken.
It may be a coil problem because when I press in on it, I get a coil scraping noise, but what confuses me is that when I turn the woofer on its side, I hear a metal clanging noise, like something is sliding to that side.
I am wondering if someone knows what this problem is? I looked around for answers and could only find people complaining about voice coil issues - not about metal clanging. Also if you know what the problem is, how to address it? I'd like to keep the sub. I don't know if it just needs a simple recone or more?
Thanks to anyone with any help!
Old 05-14-2013, 10:47 PM
hawaiianmaxx's Avatar
0/11 ssssss862
put a DMM on each set of terminals to see if you have an open coil. scraping could either be wires from the coil unraveled or the former bubbled. no other visual damage, triple joint, spiders, ect.
KIDS SAY THE DARNDEST THINGS-
STOP PAYING ATTENTION TO YOUR RATIO IN 4TH ORDERS!!!! Ratios in 4th orders mean about as much of the color of socks you wear.
I never said getting 60 MUSICALLY will be easy did I? Getting 60+ on a burp machine is, sorry to say that but it is.
Old 05-14-2013, 11:32 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Sounds to me it's blown and something inside came apart. Simple test for ya: Take any size battery AA or even AAA and connect a piece of speaker wire to each terminal to the battery. Should move inward or outward. If it doesn't move at all, it's def blown. Will more than likely need a recone.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-14-2013, 11:55 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
sounds to me like coil is in 2 pieces and you just need to do a recone.
My game is legit,
Old 05-14-2013, 11:59 PM
0/11 ssss12531
Sounds to me that ballzfast needs to quit coming in here and saying sounds to me as I did!!!
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-15-2013, 12:08 AM
0/11 ssssssss5
Thanks for the input guys!
I'll run those tests tomorrow and hopefully figure this all out. Most likely will just recone it. Anyone know how much a recone for a Z v.2 15 costs off hand?
Old 05-15-2013, 12:10 AM
Pieper's Avatar
Winston Churchill > You
0/11 sssss9716
Feedback Score: 84 reviews
140ish
I have a 12 doing something that sounds similar. I may tear it down this week and see what is happening
Old 05-15-2013, 12:15 AM
0/11 ssssssss5
Thanks Pieper, if you can, let me know what the cause of it was and what exactly is broken.
Old 05-15-2013, 02:39 AM
Gary F.'s Avatar
0/11 ssssss428
Shorting ring has came unglued.
Old 05-15-2013, 11:35 AM
0/11 ssssssss5
And how could I go about fixing it? Just contact Sundown?
Thanks for all the help so far everyone!
Sticking metal to metal jt_buck Sound Deadening & Fabrication 31 10-22-2011 01:07 PM
new metal song korey_hofer Off Topic Chat 1 02-13-2011 05:00 AM
More then metal..... ModFreak (Tool Maker) 7 07-27-2010 08:55 PM
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 07:59 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
