dsc1500.1 to .5ohm? - Car Audio Classifieds!
Old 05-14-2013, 11:13 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default dsc1500.1 to .5ohm?
is it a bad idea to...drop a dsc1500.1 to .5ohm?
Old 05-14-2013, 11:20 PM
cerwinvega_fan's Avatar
Loyal Member
0/11 sssss1788
for daily? Wouldnt recommend it... just my 2cents
Old 05-14-2013, 11:22 PM
Ryan1126's Avatar
0/11 sssss9178
yes for daily, im really not worried about smoking it, i really just dont want to have to go through the whole ordeal of swapping amps at the moment, but i guess ill have to.
Old 05-15-2013, 12:02 AM
0/11 sssss5305
Had a team mate who ran Mbquart Ryvals? (lowest model) strapped at .33 daily. Yes .1625 per amp. Played music just fine, but did get very hot...
Old 05-15-2013, 10:45 AM
Ryan1126's Avatar
0/11 sssss9178
well the thing that makes me hesitant is the 4g inputs.
Old 05-15-2013, 10:51 AM
0/11 ssss31258
buy better 4 gauge
Old 05-15-2013, 11:03 AM
Ryan1126's Avatar
0/11 sssss9178
Originally Posted by iamsonic View Post
buy better 4 gauge
i have AT 0g to a distro, and from there i have stinger HPM to the amp. But even with good 4g i thought anything over roughly 1500 watts you should be using 0g?
Old 05-15-2013, 11:14 AM
0/11 ssss31258
sorry, I didn't give a lot of thought to it, I'm sour about new wire not being as good as old wire.
the capacity depends on the length. 3ft or less of real OFC 4 gauge is good for over 150 amps of current. {1ft should be double that}
The DSC1500 is fused at 140amps.
If you draw more than 140, you'd need to replace the fuses and find a way to increase your current capacity.
1800 watts without 'loss' = 150amps @ 12volts
Old 05-15-2013, 11:16 AM
Ryan1126's Avatar
0/11 sssss9178
oh okay, well the 0g is CCA, and the HPM is OFC, and its about a foot length from the distro. Think i should try it and just see how hot the amp gets?
Old 05-15-2013, 11:22 AM
0/11 ssss31258
If no one chimes in and says the amp will do it, I wouldn't try it.
the problem is the transistors don't 'overheat'. They just explode/blow up when you exceed their capacity.
Is this a bad idea? jwright0291 General Car Audio Discussion & Questions 8 02-16-2012 03:19 PM
is this a bad idea? hdman87 General Car Audio Discussion & Questions 9 08-03-2011 07:00 AM
Bad idea to drop in and say hello to a company? mattintc10 General Car Audio Discussion & Questions 25 04-03-2011 01:38 AM
good or bad idea to use this battery arntsmag General Car Audio Discussion & Questions 1 07-21-2010 10:02 PM
Good idea or Bad idea? Ccab81 General Car Audio Discussion & Questions 6 02-16-2010 06:31 PM
