Why does TL show 57hz when I played a 43hz tone? - Car Audio Classifieds!
Old 05-15-2013, 02:22 AM
0/11 sssss1741
Default Why does TL show 57hz when I played a 43hz tone?
I played a 43hz tone to get this.. its showing 57, as far as I know.. I really dont know a lot about the TL yet.. Just doesnt seem like it should be saying 57hz on it..
I also dont know how to find my peak frequency with the TL, If anyone has any advice.. I just learned about the k factor or whatever, I never knew I had to enter that number off the sensor into the program..
EDIT: Actually I think the peak frequency on it says 11, either way none of those numbers sound right..
[ATTACH]42801[/ATTACH
File Type: jpg 976897_10151665770673530_637081621_o.jpg (71.4 KB, 91 views)
Old 05-15-2013, 02:45 AM
Masterofallbass's Avatar
Team Minnesota's Loudest
0/11 sssss1973
yeah theres something wrong with the program or instacal
2010 MidWest Spl: Xtreme 1 Champion - Kaos Champion - No Wall 3rd Place
2011 MidWest Spl: Xtreme 3 3rd Place - Advanced 2 6th Place
2012 MidWest Spl: Xtreme 3 3rd Place - Advanced 2 5th Place
2013 MidWest Spl: Xtreme 4 3rd Place - Advanced 3 6th Place
2014 MidWest Spl: Xtreme 4 Champion - Kaos 4 2nd Place - Advanced 3 3rd Place
2015 USACI: Street Beat 4 World Record Holder
Old 05-15-2013, 11:02 AM
The spectrum analyzer on the bottom shows a range of frequencies, not just one. I can't make out what it says though. Try a different tone source.
Old 05-15-2013, 03:34 PM
0/11 sssss1741
If I understand what you're saying correctly, How can I even get an exact frequency off the graph? Just have to guess?
I think Im going to reinstall all of it and see what happens..
Old 05-15-2013, 03:48 PM
0/11 ssssss972
Feedback Score: 23 reviews
The TermLab holds the peak frequency...So if you are trying to find a peak, run a sweep, or simply start low and go up in frequencies...It will continue to hold the loudest one. Assuming you use the mode that holds peaks, not rta.
Old 05-15-2013, 03:52 PM
I think the termlab gives you your peak frequency regardless of the source material. That's how you get metered on, for example, music, where the frequency is changing a lot. If your single-frequency test tone has a small Q factor it can "spread" to a wider range of frequencies. The score listed is the correct dB at the displayed frequency, just not the one you expected.
Old 05-15-2013, 03:54 PM
0/11 sssss3232
Feedback Score: 17 reviews
just cause you played 43hz doesn't mean you peak at it let others say try a sweep.
TEAM420
TEAM XSPOWER
TEAM DC AUDIO
SS 1-2 3rd PLACE 2007 INDY "REGIONALS"
SS 1-2 1ST PLACE INDY AND 2008 NATIONAL CHAMPION.
Old 05-15-2013, 04:16 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
I am inclined to think you didn't play a tone.. But a song that "peaked" at 43hz. If you played a 43hz tone then the graph should have one large bar at 43hz and possibly two smaller bars on the right and left of it.
If you did infact play a tone then your program/sensor is probably fugged up.
Current Build:
#60sHereIcome
Anton Miller's Avatar
DoucheMiller
0/11 sssss3720
he "reset" then burped 43 hz and it showed up at 57 hz and a block of freq ont he analyzer showed up. im assuming its a wire of some sort. a fresh install will be good to check but I think its a cord. kind of like when you unplug the mic and re plug it in it shows a WIDE range of freq and a high score....
1997 CHEVY CAVALIER - BUILT FOR EFFICIENCY!! YOUTUBE:
Old 05-16-2013, 01:00 PM
0/11 sssss1741
Does anyone know if the cord for the mic is a standard ethernet cord? I am going to try that quick if its just a standard cord, which i think it is.. If not I am going to reinstall all of the stuff for it..
u like ur prostate being played with? upzaw2000 Uncensored Off Topic 12 05-31-2011 03:48 PM
2 Never Played MTX TR7515's Joker6167 15" Subwoofers 3 04-01-2011 07:58 PM
My conspiracy that everybody played a part of ;) 98HOEONSIXEZ Off Topic Chat 13 08-31-2010 02:46 PM
Played with the TL - How did I do? SPY General Car Audio Discussion & Questions 36 10-25-2009 08:22 AM
