whats wrong with my 4th? a little help please. - Car Audio Classifieds!
Old 05-15-2013, 06:10 PM
0/11 sssssss56
Default whats wrong with my 4th? a little help please.
Ok to start heres where im at:
2000 Audi A8
Blow through the rear deck
2 15in Incriminator Audio Death Penaltys D2
Powerbass XTA 5k @.5
Tenney 320 amp alt
2 Shuriken BT 120s
Enclosure is:
3.5 sealed separate chambers
7 ported
Port is 20x6.5x7.5 tuned to 49?
Subs are firing in the direction from front and back of vehicle, port firing through rear deck going up.
So far my frequency range with this port is 32+ peaking at 38 148.3
Really lacks lows.
Ive added 3/4in internal port walls on the 6.5in sides. 2 layers on both sides making my port 17x6.5x7.5.
This gave me a little better lows and still a decent range (28+ now) but brought my score down a few 10ths.
My question is, is the reason my lows are horrible cause of my subs? Or my port? Or my enclosure?
What could I try to be able to play lows better and also make them forceful?
Any help would be great! Thank you.
Old 05-15-2013, 06:16 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
7 ported total or per sub
Old 05-15-2013, 06:17 PM
0/11 ssssss133
How low do you want to play?
Get the sealed section to resonate at say, ~40Hz and tune right at sealed resonance and see what happens.
Might be able to get the sealed section there with polyfill.
Old 05-15-2013, 07:30 PM
0/11 sssssss56
Im at 3.5 total sealed. 7 total ported.
Old 05-15-2013, 07:33 PM
0/11 sssssss56
I just want to play down to say 20 safely.
Will polyfill help lower my sealed resonance? If so, how much, where do I get it and do I just put it in there?
Does this mean my sealed side is to small? 1.75 per 15.
Old 05-15-2013, 09:28 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
Apparently it is either to small or your tuned to high. Did you check your sealed resonance before you put the port wall in?
2000 2dr Blazer
Old 05-15-2013, 10:41 PM
0/11 sssssss56
No. Dont know how to do that. Also the way the box was made the panel to make it sealed was the last panel to go on. Had to build it in the trunk.
Old 05-15-2013, 10:43 PM
0/11 sssssss56
So far ive gotten the tuning down to 45is by shrinking the port. Im worried about shrinking it to much cause now im down to about 15 sq in of port per cube now. Maybe just shy of 15
Old 05-15-2013, 11:20 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
Feedback Score: 22 reviews
bring up the space on the sealed side to around 5 and tune to 45 on the ported side.
Old 05-15-2013, 11:21 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7526
And use 140sq in of port. No less more is always better.
Whats wrong with my a/c? crownvicon26's General Automotive Chat 56 07-10-2011 12:49 PM
Whats wrong with a/c? crownvicon26's Member Rides & System Pictures 2 06-20-2011 12:54 PM
Whats wrong with my xs d3400?? fyerbyrd22 General Car Audio Discussion & Questions 21 04-25-2011 01:44 PM
Whats wrong with this sub?? westman995 General Car Audio Discussion & Questions 42 11-30-2009 07:20 PM
