New alternator, idle charging issues. - Car Audio Classifieds!
Old 05-16-2013, 11:16 PM
QmarcesQ's Avatar
0/11 ssssss124
Default New alternator, idle charging issues.
Just put a new alternator in 230a.
At idle it charges at 12.6-12.8 (old 130 a alt charged at 14.3 at idle).
When I rev it up it charges beautifully, and holds the charge wonderfully at full tilt with the BTL SCREAMINGLY loud. Although briefly , not even a full second, charge jumps to 15.3.
I worry about the idle dropping so low, especially if this is gonna happen when i stop at the light and have to turn it down.
When I parka and turn the car off the batterys sit at 12.6-12.8 but after sitting for 20-30 minutes it jumps back up to 12.93 resting voltage.
Did i do something wrong with this install that the charge is weird or do i just need to bump up my idle speed?
Old 05-16-2013, 11:25 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
I've seen this happen with a few dif alts I've put in peoples cars... usually just adjust the throttle set point so it idles a touch higher...usually it only needs a little like 100-200 rpm and it activates the alt full charge
Old 05-16-2013, 11:27 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Smaller pulley to pick up at idle, also recharge batts overnight
Old 05-16-2013, 11:34 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
yup.. like they said smaller pulley. And FYI the alt isn't charging if voltage isn't above 13.
Current Build:
#60sHereIcome
Old 05-16-2013, 11:56 PM
QmarcesQ's Avatar
0/11 ssssss124
whats the easiest way to adjust the idle on a ford escape? i mean i have a few rigged ideas that will work, but what is the official real way? a google search doesnt tell me much about increasing just resetting the idle speed
I had it on a charger for the 6 hours it took me to get this beast installed (first alt install ever :/) so they are decently charged and they rest at 12.9-12.93
Old 05-17-2013, 12:31 AM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Don't mod Ur Escape.. just go with a smaller pulley to make it spin a little faster..
I have a Ford Escape too.. a real pain to work with
Sent from my DROID RAZR using Xparent BlueTapatalk 2
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 05-17-2013, 12:33 AM
Team SPL Farms
0/11 sssss5000
Is it an ebay or is it from a vendor?
Old 05-17-2013, 12:39 AM
QmarcesQ's Avatar
0/11 ssssss124
Singer alternator.
Old 05-17-2013, 12:41 AM
QmarcesQ's Avatar
0/11 ssssss124
It was such a pain to get to the alt, i had to jack it up on a lift, remove the ****ing wheel and than the splash guard, and all this plastic shit attatched to the alt itself to be able to get it to fit out. i would really like to avoid having to mess with that again :/ plus if i plan on competing they dont let me touch the throttle and max idle is 1200 so it would be nice to have it at idle to be prepared for that.
Old 05-17-2013, 12:59 AM
Team SPL Farms
0/11 sssss5000
If you just change pulleys u only need to access t he nut that holds it on. If u email him and let him know he work it out w you. He wound up sending me a diff pulley for the same reason on my car. Hes a good dude n he will straighten it out
FS/Trade: 300 Amp Iraggi Alt / 170 amps @ idle Alternator MrClean636 Wiring, Electrical & Other Installation Equipment 6 05-15-2013 02:29 PM
Mechman 240 amp alternator bracket issues wccfan General Car Audio Discussion & Questions 0 05-10-2013 11:24 AM
Idle Voltage PapaGeno21 General Car Audio Discussion & Questions 10 03-05-2013 08:58 AM
up my idle? Nd_6037 General Automotive Chat 19 09-18-2010 08:19 PM
200 amp/150 amp idle chevy/gmc alternator dual rectifier jdubbau Wiring, Electrical & Other Installation Equipment 0 03-09-2009 12:57 AM
