amp rack ideas - Car Audio Classifieds!
Old 05-17-2013, 11:24 AM
0/11 ssssss772
Default amp rack ideas
i need some advice how to make my amp rack also with some cooling fans to keep it cool on my 2002 impala i have 2sa12s so any ideas would be greatly appreciated
Old 05-17-2013, 12:05 PM
socalxj's Avatar
0/11 sssss2371
More input is needed...as in where or what or how much...I like mounting amps hanging from under the rear deck using all thread and lock nut's and washers...can hardly see it when trunk is open and harder to remove than most thieves would care to spend stealing yo chit! Here's my fiance's car...
Old 05-17-2013, 12:07 PM
Mr.G6's Avatar
0/11 sssss4614
i hate when i see people do this
defeats the purpose of a heatsink
lets all that heat radiate right back up to the board..AND if you actually have some bass that rear decklid will flex like a mofo
proper installs usually deter thiefs if done properly
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
05TRAILBLAZER (05-17-2013)
Old 05-17-2013, 12:11 PM
Mr.G6's Avatar
0/11 sssss4614
wow that wiring job is totally not acceptable for me lol
heres a simple secure way of mounting the amp and battery
and a fan too
just build a "box" a good 3" taller than your battery..and the length of the amp
use blocks inside to secure the battery ( youll have a big empty section now)
use that area to hide your wires n such and simply cut a square hole for the fan and remove the back of the amp so it blows on the board..
screw that box down to the wood platform you already have
Old 05-17-2013, 12:13 PM
0/11 ssssss772
yes his setup looks nice its diffrent but tryin to hold amp and mount would be a bitch but i figure also the vibratin would cause some effect
Old 05-17-2013, 12:16 PM
0/11 ssssss772
and a fan too
well this was a temproay setup any way to see how the subs do in this box with this amp and it slams hard
Old 05-17-2013, 12:17 PM
Mr.G6's Avatar
0/11 sssss4614
did you totally miss the idea i threw out there??
simple box idea hides battery..wires and secures the amp
Old 05-17-2013, 12:23 PM
0/11 ssssss772
well no i didnt miss idea i was reply to what u sayin bout u didnt like the the wiring setup
Old 05-17-2013, 12:29 PM
Mr.G6's Avatar
0/11 sssss4614
thats just because im super anal about the little things lol..
dont get mad.. i told my best friend this morning his wiring lookd like ass too lol.. cleaned it up for free because it bugged me that much
i stopped him mid demo and shut it off and went to work lol
also with the box idea you will have room for 1 more xs power battery if need be
or you could get metal L brackets bend em slightly..screw them to the wood platform you have and screw a panel to the brackets
( look kinda like a 45 degree panel basically) and finish it off how you wish
Old 05-17-2013, 12:30 PM
0/11 sssss8594
Feedback Score: 55 reviews
Enclosures
Help me with amp rack ideas for a monte Nik592 Sound Deadening & Fabrication 3 07-09-2012 08:04 PM
Amp rack ideas? stevenminix General Car Audio Discussion & Questions 5 01-31-2011 03:02 AM
center console amp rack designs/ideas? RE_Gawker Enclosure Discussion & Design Construction Help 7 10-06-2009 08:31 PM
Patrick's CACO amp rack and trunk panel ideas Patrick Simmons Enclosure Discussion & Design Construction Help 31 01-18-2009 05:19 PM
Need Ideas for Amp Rack and Battery Rack! BassikInstincts General Car Audio Discussion & Questions 8 01-15-2009 10:36 AM
