Lowest safe voltage on sundown 3500 - Car Audio Classifieds!
Old 05-17-2013, 08:13 PM
QmarcesQ's Avatar
0/11 ssssss124
Default Lowest safe voltage on sundown 3500
What is the lowest voltage you can drop to and be safe with a saz 3500 from sundown?
While revving i generally have great charging in the upper 13-14. while idle my alt isnt charging at full capacity (trying to figure out upping idle speed currently to fix this) when i pull up to a light or even just coasting down the street ,not accelerating, my voltage sometimes drops to 12.8-12.9.
Is dropping that low going to hurt the amp for a few moments?
What is the lowest voltage i can safely drop to without worry for maybe a minute or so (red light/stop signs) The manual says operating voltage is 10v-18v. I have a 230a singer alt in there and 3 sprinter battery's plus a yellow top ~300ah total.
Old 05-17-2013, 08:18 PM
massivespl's Avatar
0/11 sssss8409
turn ur music down at stop lights. dont be that a-hole that is annoying at the stop light.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
The Following 2 Users Say Thank You to massivespl For This Useful Post:
art1618 (05-17-2013), thericanballer (05-17-2013)
Old 05-17-2013, 08:24 PM
QmarcesQ's Avatar
0/11 ssssss124
most of the time i am alone on the road, the road i take doesnt usually have many people on it, plus the issue also occurs while cruising (not accelerating)
Old 05-17-2013, 08:26 PM
massivespl's Avatar
0/11 sssss8409
i dont like my voltage to drop lower then 12.8v... my batteries resting voltage is 12.8 so if i get down that low im only using ALT power. if u want to stay above 13v u need a bigger alt or dual alts. or just rev your engine.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 05-17-2013, 08:29 PM
PsychoSoundz's Avatar
0/11 ssssss132
you should be fine long as you are in the 12v range..but no lower. id turn it down some if it goes farther. whats your electrical like besides the alt
Old 05-17-2013, 08:31 PM
massivespl's Avatar
0/11 sssss8409
he said I have a 230a singer alt in there and 3 sprinter battery's plus a yellow top ~300ah total.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 05-17-2013, 08:34 PM
QmarcesQ's Avatar
0/11 ssssss124
230 singer alt (he says it does 250a) its the biggest one my 4cylinder can fit and push according to dc,mechman, tenny and singer. Dual alt is out of the question as well from what i understand.
would an additional sprinter help with that drop at idle? and if i go below 12.8 that means its no longer using the batterys just the alternator to power the amp? because even with the amps and radio powered off the car idles at 12.6v. i shut the car off and it slowly bumps back to resting at 12.83.
and just how low into 12 is safe? absolute lowest i have seen was 12.3 on a kick while idle.
Old 05-17-2013, 08:38 PM
massivespl's Avatar
0/11 sssss8409
no once u are drawing more current then your alt puts out then you are going to use batteries. u should be fine at 12.3but lower voltage can make you get a clipped signal. i say mid 12's is the lowest you wanna go.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Man Behind the Curtain
0/11 sssss1699
What car is it? What part of Plano you in? If it's in the 12s your ok. Getting into the 11's is not good.
Old 05-17-2013, 08:40 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
you are fine. I used to drop into high 10's on my american bass amps and never had an issue. people on here go overkill with electrical. that being said 11.5 is my minumum before i back off the volume knob. DD amps are tested at 11.9 volts. They are korean built. most korean amps should be fine that low if not lower.
Safe input rca voltage for saz1500dv1? graham General Car Audio Discussion & Questions 0 03-07-2013 06:17 AM
Mmats 3500.05 @ high voltage?? Bsktbll895 General Car Audio Discussion & Questions 1 11-02-2012 10:27 PM
AQ 3500, Sundown 3500 something similar 423bass Wanting to Buy (WTB) 2 09-11-2011 03:01 PM
safe voltage drop ? chuck5766 General Car Audio Discussion & Questions 28 03-06-2011 11:27 AM
What do you consider "safe" voltage drop 6btdakota General Car Audio Discussion & Questions 10 01-05-2011 02:34 AM
