efficiency effectiveness with voltage change - Car Audio Classifieds!
Old 05-19-2013, 11:35 AM
SPL Distribution Owner
0/11 sssss2983
Default efficiency effectiveness with voltage change
I was looking at an amp the other day and had a question to see if this is common or just for this amp.
I will as fortunate enough to see the manufactured current draw and output power so calculating efficiency was easy.
As follows-
1 ohm-
14.4v 78%
16v 77%
18v 71%
I thought higher voltage was more efficient.. Am I wrong?
Old 05-20-2013, 02:04 PM
n8skow's Avatar
0/11 sssss1519
Higher voltage is more efficient (versus higher current)... Perhaps it's a misprint on their end?
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
Old 05-20-2013, 05:25 PM
0/11 ssssss546
What amplifier is it?
Old 05-20-2013, 05:28 PM
0/11 sssss2983
I'd rather not say right now as i dig up more information from other companies.
This is so opinions and bias information are not involuntarily brought into the discussion.
Old 05-21-2013, 04:32 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
That is very interesting indeed.
Let's see... 300A draw.
14.4v - 3,370w
16v - 3,700w
18v - 3,835w
Yeah... that doesn't look right. Lol.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 05-21-2013, 05:13 AM
0/11 sssss2429
Feedback Score: 46 reviews
The higher input voltage also means most circuits also have to dissipate more power. Hence the 15V zener used to clamp the gate drive voltage. At 14.4 it wouldn't even conduct, anything higher and wasted power. Also the +-12V and 15V regulators are now forced to dissipate more power. So I can see efficiency dropping off.
Old 05-21-2013, 06:55 AM
0/11 sssss2983
14.4v - 3,370w
16v - 3,700w
18v - 3,835w
The higher the voltage, the more current it draws!
I always thought the current draw difference would be minimal as it almost non measurable but i was wrong.
Based on this one particular amp, current draw increases from 14.4v to 18v by 22%.
So then this isn't uncommon.
I had someone else give me a different point of view on this too-
If efficiency is the primary objective, then as an engineer standpoint, I'd be focusing on making the amp the most efficient at the typical voltage range it is to be played at.
If you notice, 14.4v and 16v are near the same.
Running 19v charging system, typical voltage drops from a large system and not enough alt will drop from 17 to ~16v and 12v, if strong, can reside between 13.5-14.5v so it makes sense.
Old 05-21-2013, 07:09 AM
0/11 sssss2429
Also if the voltage drops to low then the fets begin to heat up causing more inefficiency.
Old 05-21-2013, 07:17 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
WTF? I was always under the impression the voltage was just making the same current "work harder". Kinda like increasing water pressure without increasing the volume. a' la - thumb over the hose.
4x world champ
- Floyd E. Toole
Old 05-21-2013, 07:20 AM
DLP customs
Guest
0/0 sssssssss
I always thought the same thing. Im pretty much mindblown right now. Brandes and shizzon need to continue.
Name change please lantz Talk with the staff 13 07-10-2012 12:58 AM
Name Change? MaliBOOM Talk with the staff 17 09-22-2011 08:34 PM
considering a change bones22 Technology & Computer 14 12-26-2010 10:18 PM
random change in voltage when its cold? SQLbeliever General Car Audio Discussion & Questions 3 12-01-2010 09:55 PM
Name change? Kyle Announcements - Suggestions - Feedback - Support 11 10-29-2010 03:43 PM
