Tuning rear deck port? - Car Audio Classifieds!
Old 05-19-2013, 08:05 PM
0/11 sssss4519
Default Tuning rear deck port?
So I'm about to help a buddy with his impala install but his back seats don't fold down. so I was pondering the idea of figuring out the remaining volume of the trunk after everything is installed and when we rebuild the rear deck actually tuning the vent so it's basically a 6th order.... Anyone done this with good results or should we just cut out as much of the rear deck as possible and call it a day. Running two MT/PSI 12''s on a skar4500.
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 05-19-2013, 08:17 PM
far to many leaks for it to work like that. you will never get the results you tried to come up with between panel flex and leaks, plus the seats screw stuff up.
Old 05-19-2013, 08:33 PM
0/11 sssss4519
so just cut the rear deck out some and call it a day?
resolve Vas/28.32 =
result of that +1
Old 05-19-2013, 08:41 PM
vince79vette's Avatar
0/11 sssss2011
U could do a 4 order and have the ports come out the deck
Old 05-19-2013, 08:56 PM
I'd just cut it out.
Old 05-20-2013, 06:48 AM
0/11 sssss4519
His box is already built. Would you cut out the rear deck and put breathable cloth over the factory deck or trim it out and leave it open but no depth to it so it's not really tuneable.
resolve Vas/28.32 =
result of that +1
4th order port through rear deck need design help, and build help in MN or IA area maddog2099 Enclosure Discussion & Design Construction Help 6 05-21-2011 09:19 PM
Port through rear deck, 4th order? Jh8909 Enclosure Discussion & Design Construction Help 11 02-06-2010 12:10 AM
Rear Deck pyromanaic414 General Car Audio Discussion & Questions 7 10-18-2009 02:50 PM
My rear deck _AnGeL_ Car Audio Videos 0 08-03-2009 08:39 AM
Rear Deck rattle? mazda6i07 Off Topic Chat 5 11-21-2008 10:36 AM
