Electrical problem, ruining batts, need help! - Car Audio Classifieds!
Old 05-20-2013, 10:08 AM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
Default Electrical problem, ruining batts, need help!
I have a 2000 explorer and I think I have a bad ground or something, it's been going on for a while now, but its melting and corroding my XS d6500 under the hood. I've ran a new groung from the battery to the frame and from motor to the frame. I'm still having issues and it started to effect my other 3 batts so I took them out.
Does anyone have any thought or any way to run some tests?
I've ripped everything out due to this issue and its driving me nuts
This was takin like 6 months ago. Bought new terminals and its still doing the same thing
Old 05-20-2013, 10:20 AM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Surprisingly, the batt runs and tests fine too
Old 05-20-2013, 10:25 AM
0/11 sssssss89
I'm not there to trouble shoot it but from my pov it looks like you have a loose connection at that terminal
Old 05-20-2013, 10:29 AM
massivespl's Avatar
0/11 sssss8409
how did u have the distribution block on there? looks like u had it resting on the handle? having a bad connection
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 05-20-2013, 10:30 AM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
^^ x3. the block looks like its not sitting flush with the pad. just sit there and arc the whole time
-Youtube Channel
Old 05-20-2013, 10:32 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Corrosio=resistance resistance=heat which equals what you have there. You say you have one frame ground and one and thats it?
Big 3 is negative terminal to body, negative terminal to alternator casing, negative to frame.
Try that and see what happens. You can measure resistance with a DMM.
Old 05-20-2013, 10:33 AM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
They're from toolmaker, and they do sit flush, but with the heat it was generating and the corrosion it started to melt the casing. I even bought new ones and still having the same issue
Old 05-20-2013, 10:35 AM
Ja Marcus
0/11 sssss6975
From this picture it looks like they were sitting in different directions.
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
The grounds I have
Batt to chassis
Batt to frame
Batt to alt mounting bolt
Frame to batt
Old 05-20-2013, 10:36 AM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Nope same direction
Problem with electrical!?!? Shakindablock General Car Audio Discussion & Questions 16 04-01-2013 03:16 PM
electrical problem i just cant handle buickman General Car Audio Discussion & Questions 24 11-29-2012 08:09 PM
Electrical problem treylittlefield General Car Audio Discussion & Questions 33 03-05-2012 11:27 AM
Electrical problem? Big 2/3, 3 batts. And lights/ACC is flickering when cars on?? AuZy_AuDiO General Car Audio Discussion & Questions 8 04-08-2010 02:07 PM
Need help diagnosing electrical problem. RE_Gawker General Car Audio Discussion & Questions 11 12-04-2009 11:07 AM
