Input needed from those of you with Audiocontrol Epicenters!!! - Car Audio Classifieds!
Old 05-20-2013, 02:37 PM
0/11 ssssss322
Default Input needed from those of you with Audiocontrol Epicenters!!!
I think my Epicenter is not working correctly, but I do not have another one to compare it to.
Even when the remote knob is turned completely down (counterclockwise), the Epicenter light still flashes, and it distorts the waveform.
If I play a straight 40Hz wave, I see a 40Hz wave on the output, but every other positive cycle of the waveform is attenuated partially. (Used a Fluke scope to see this).
When I called Audiocontrol, they said it should do this if you play a straight sine wave through it. Something about it looking for upper harmonics and such? This sounds wrong. When I do not turn the knob to activate the circuit, the thing should not be altering the waveform. I do not think it ever used to modify it before, but I have no scope proof.
Can someone verify if the Epicenter light flashes if they play a straight sine wave and do not turn the knob?
Thanks!!
Old 05-20-2013, 02:53 PM
villeza1's Avatar
0/11 ssssss544
Whats the signal look like before the epicenter?
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
Old 05-20-2013, 03:11 PM
0/11 ssssss322
Pure sine wave from DbDrags CD. Non clipped signal. Not full range.
Old PPI Art input needed please. jwiLx General Car Audio Discussion & Questions 16 10-03-2012 07:18 AM
underseat box build input needed green monster Enclosure Discussion & Design Construction Help 1 04-18-2012 10:11 PM
New CACO home page - input needed old CACO Admin Announcements - Suggestions - Feedback - Support 7 06-05-2011 04:06 AM
input needed pitbull1078 General Car Audio Discussion & Questions 8 01-28-2011 10:48 PM
Moped Build *input needed* aturcotte127317 Miscellaneous Build Logs 31 07-20-2009 03:41 PM
