OPTI2000D VS Sound Stream Tx1.2600D - Car Audio Classifieds!
Old 05-20-2013, 05:06 PM
0/11 ssssssss5
Default OPTI2000D VS Sound Stream Tx1.2600D
Hi guys i have a dilemma on which 0.5 stable amplifier would be the best choice for my needs. I have 4 RE Audio SEx12D4 subs and need to know which 0.5 ohm stable amplifier you all would choose to power these subs. I have them in a custom quad 12 sealed enclosure built to RE Audio specs, made with 1" MDF, and also has 4+ coats of fiberglass resin. I am on a budget and found these two 0.5 stable amplifiers that would meet my power requirements. My car has a 220amp PowerBastard alternator, all 2/0 Awg 100% Copper welding cable, including Big 3 upgrade, an XS Power D3400 Group 34 AGM Battery up front, and a Kinetic HC1200 AGM battery under amp rack in trunk. I will only play system with car running, as of now my sitting voltage is a steady 14.8 volts without A/C on and 14.6 with A/C on. I live in the south so temperatures can reach upward of 104+ degrees. I was wondering which amplifier a Lanzar OptiDrive Opti2000D or Soundstream Tx1.2600D would you all choice to run these subs. All subs are wired parallel to make a 0.5 ohm mono load... Please help!!!!!
Old 05-20-2013, 05:13 PM
KEVGNAR's Avatar
0/11 ssssss928
i would look into a bc2k if you can save a few more buck up for it, imo i would stay away from those amps just from other experiences lol but that is entirely up to you. any pics of your box? i love me some RE audio
Even though this is definitely not built for numbers, demos speak a thousand words...
1990 Oldsmobile Cutlass Cruiser
Old 05-20-2013, 05:27 PM
Wingman0121's Avatar
0/11 sssss2171
The Lanzar Opti2000D is a proven amp (it's fairly old actually) and it will pull a daily .5 ohm without a problem. Never really hear anything bad about the Opti besides its somewhat bland exterior.
Old 05-20-2013, 05:30 PM
0/11 ssssss546
I'd get the Sundown.
Oh wait...
Old 05-20-2013, 05:34 PM
0/11 ssssss546
I have a Opti4kD (same as S/S 6500 but more realistically rated)
The thing is a monster, it's been beaten up over the years but still works flawlessly - it's a keeper.
Out of the two... Lanzar
Old 05-20-2013, 05:40 PM
massivespl's Avatar
0/11 sssss8409
Opti 4sho
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 05-20-2013, 06:13 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Sealed enclosure?? Those subs would do better in a ported.....unless your going for SQ. I would suggest other brand name amps to handle your .5 ohm load too.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 05-20-2013, 06:18 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
i wouldnt go with the soundstream to run at .5 ohm, ive used a few and they didnt hold up at a .5 ohm load....granted they really arent meant for it. But i did have a smoke show with a soundstream pcx2000d and a rubi2500.1 both on good electrical. Could have fried eggs easy on either amp after minutes of play time. Id say opti, but i have no experience with Lanzar. Now on the other hand i ran one of my Crescendo bc2000d's at .5 ohm its whole 2 1/2 year period i had it for and it never had one bit of an issue, not even heating up.
2013 Toyota Highlander
Build to come.....
Old 05-20-2013, 06:42 PM
Quisdccc's Avatar
Awaiting Confirmation
0/11 ssssss355
Soundstream Tx1.2600D is my choice....I have one in my blazer now and it runs .5 all day spent the last month running it daily at .25 so it should handle the .5 easy. I also clamped atleast rated out of it. And with its rating if you do usaci you can run 0-600
Old 05-20-2013, 06:52 PM
0/11 sssss3693
i believe the tx1.2600 does its 2600 at .5ohm right? i think those are the amps EXO ran to his ss xxx's....but .25 is a little low id say but you must be rising quite a bit so the amp when being played isnt actually seeing a .25ohm load
Build to come.....
Soundstream tx1.2600d amp for sale trajec1211 Mono Amplifiers 8 04-24-2013 09:59 AM
wtb 2 soundstream tx1.2600d Nate Futuristic Wanting to Buy (WTB) 0 02-28-2013 07:35 PM
SoundStream TX1.2600D dk8989 CACO Amp Internals 3 11-22-2012 08:52 PM
Sound Stream mickey Wanting to Buy (WTB) 0 12-06-2011 10:07 PM
Sound Stream T4 15 TKCARAUDIO Broken & Non-working equipment 10 07-17-2011 04:58 AM
