Need amp help bad fellas... The only thing that's holding me up.. - Car Audio Classifieds!
Old 05-21-2013, 10:13 PM
MrOneEyedBoh's Avatar
0/11 sssssss98
Default Need amp help bad fellas... The only thing that's holding me up..
What's up guys. Here's the low down. I have everything set up to buy but I'm stuck on my two amps. I need amps for my components and my sub.
Components are ID ctx65. 100rms 4ohms
Sub is a RF P3SD4 ( or 2 ohm ) 12". Dual voice coil 400rms.
I'd want to over shoot the RMS on the amps to account for efficiency to an extent.
I'm on a slight budget of around $300.
I was thinking for the components to get the hifonics zrx500.2.
And the sub, Rockford Fosgate R500X1D.
Any suggestions guys would be appreciated...
Old 05-21-2013, 10:31 PM
qopiyu's Avatar
0/11 ssssss531
I would get:
Audio Technix 800 1 Amp Amplifier 800W RMS 2000W Max Class D 1 Ohm Stable | eBay
and
Precision Power P900 4
total is about $335. The PPI will offer you the ability to go active on the comps with the built in crossovers and from what I have read about both of these amps... they will not disappoint!
The Following User Says Thank You to qopiyu For This Useful Post:
MrOneEyedBoh (05-22-2013)
Old 05-21-2013, 11:26 PM
0/11 sssssss98
Thanks man. Which version of the sub should I go with 2 or 4 ohm?
Old 05-21-2013, 11:30 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
clear away from the rockford man, much better out there for the money. look through the classifieds. get that Audio Technix amp and get a D2 sub that is rated for 600rms. SA-12, lvl3, vvx12, etc... list goes on my friend.
messege me if you would like for some guidance because im sure i just kind of blind sided you there.
The Following User Says Thank You to Ryan1126 For This Useful Post:
Old 05-21-2013, 11:34 PM
0/11 sssssss98
Gopiyu,
Also on that AT sub amp you recommended, are they underrated? Does it push more than 400rms? I wanted something that was around 500 to account for inefficiency...
Old 05-21-2013, 11:36 PM
0/11 sssssss98
Just an FYI on why Im looking at that sub, I need to go with that shallow sub that I listed. That sub was recommended to be from SPL2k, the guy that makes boxes specifically for my truck. Look him up. He said that sub ( and two others ) perform the best in his boxes.
Old 05-21-2013, 11:37 PM
0/11 sssssss98
Do you guys think its okay to go with this sub, its used and I can save 40 bucks. Im WAYY over budget
Audio Technix AT800 1D Monoblock Amp Gently Used Excellent Shape Nice | eBay
Old 05-22-2013, 02:19 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Dont see why not, looks to be in good shape. Not sure if the new ones come with a warranty of any kind but if they do its certainly worth 40$.
It's better to keep your mouth shut and give the impression that you're stupid, than to open it, and remove all doubt.
Mistakes are how you learn; try not to learn too much at any one time.
Old 05-22-2013, 08:16 AM
qopiyu's Avatar
0/11 ssssss531
The amp is under rated .... will do roughly 1200 at 1 ohm.
Old 05-22-2013, 08:57 AM
Mr.G6's Avatar
0/11 sssss4614
Gopiyu,
ok.. do this first.. some research
youll find that the Audio technix are a korean amplifier..better than 99% of china shit out there ( kicker rockford etc etc)
that little 800.1 has 120amp worth of fusing
now go look at other 1200w rms rated amps ( that are again rated for 120amps.) just the fuse rating alone should tell you its slightly underrated for sure
always do the BIG 3 upgrade too..
2000 Gmc Sonoma ext cab
The Following User Says Thank You to Mr.G6 For This Useful Post:
HOT alternator!! is that a bad thing?? beatnbronco General Car Audio Discussion & Questions 35 06-09-2012 11:47 PM
Screws holding sub keep coming loose.... AR-15 General Car Audio Discussion & Questions 31 06-16-2011 07:48 PM
I want this thing so bad!! Violence* Off Topic Chat 12 07-28-2010 08:06 PM
Is ebay holding money on electronic sales now? CleanNMean General Car Audio Discussion & Questions 22 11-23-2009 09:53 AM
