Digital Designs general discusion - Car Audio Classifieds!
Old 07-12-2013, 02:23 PM
0/11 sssss2649
Default Digital Designs general discusion
This thread to discuss general Digital Designs products. DD is coming out with a lot of new equipment lately; 21" DDZ, super 8 (high excursion 8 with 2500 series motor), 9900 (4" coil with larger then 9500 series motor), and always making changes to current models. If its info about DD audio, its not off topic.
This thread is not for "haters" or people to come here complaining that they think DD is too expensive. I made this thread because overall I have been happy with the products and want to learn more.
The new 21" DDZ discussion thread...
Digital designs new 21 inch sub!
For those that still think DD's don't plays lows... 4 9518's on 10,800 watts tuned to 37 hz and still doing 155.3 at 27 hz. 160+ kick at 46 hz.
4 9518's on 2 M4a's 400 FPS....
The Following 2 Users Say Thank You to Eocuph For This Useful Post:
2003f150 (07-15-2013), Kreepn (07-15-2013)
Old 07-12-2013, 02:32 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
I have a theory that I've yet to challenge about the myth of the no lows. The majority of people here and every other forum, has people saying to build all dd enclosures with massive ports. 18, 20 inches per cube. I've even seen more suggested. The bigger ports will play louder but usually not lower. Restricting the rear wave would bring more lows and less peak, meaning a smoother response to even higher frequencies. Dd suggests 16" per cube for a reason. With most DD's being way underrated on power handling, the average person not chasing numbers could do better lows with less port area to widen the bandwidth, and more power to raise the volume levels. Most will agree that nearly all of the DD subs could handle close to or more than double power if done correctly and cleanly.
The Following 2 Users Say Thank You to BigBen For This Useful Post:
cloud77 (02-23-2014), So Low (03-17-2014)
Old 07-12-2013, 02:56 PM
r1 banshee's Avatar
<-- all I need
0/11 ssssss288
Does any one have any pics of the new 4" coil or the new super 8"?
Subs: 2 9515's super charged
Amp: DD M4a w/Toolmaker duel inputs ,
Highs: DD CXS 6.5 (burp car)
4 kinetik hc3800, 4 run's of 1/0
Old 07-12-2013, 03:02 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
DD Nuthuggers thread
it makes since that if u add an alternator it will add resistants make your MPG go down but i dont see how turning up your volume adds more resistants.
SENSE RESISTANCE
Perhaps a mod could change it to "Massivespfail"?
The Following User Says Thank You to bigdhenderson For This Useful Post:
Blaza33 (07-12-2013)
HiloDB1's Avatar
0/11 sssss3158
I'm not a DD hater but I would not run their products. I do not agree with their business tactics (has nothing to do with pricing)
The Following User Says Thank You to HiloDB1 For This Useful Post:
kmanian1 (07-12-2013)
0/11 sssss2649
For daily enclosures, what my local DD dealer does is build his DD enclosures about 25% bigger then manufacture specs and about 17" port per cu for 2500 series and lower. 17-17.5" for 3500 series and 18+ for 9500 series. He typically tunes 36-38 hz depending on vehicle and type of music customers listen to. And all of his setups that I've heard have been extremely efficient, impressively flat, play the really fast punchy notes and still played 30hz or even mid to high 20 hz with authority.
With the huge enclosures and lots of motor force there tends to be a lot of box rise. Might be a good idea to wire down to .5 ohms.
Old 07-12-2013, 03:08 PM
0/11 sssss2649
They have some super 8 pics on DD's facebook.
lol
That's perfectly ok. I think they do a good job supporting there local dealers and I respect that.
The Following User Says Thank You to Eocuph For This Useful Post:
Crunk (07-12-2013)
Old 07-12-2013, 03:28 PM
0/11 ssssss384
Here you go. First public appearance, Dub car show in Dallas.
The Following 2 Users Say Thank You to imlouder For This Useful Post:
Eocuph (07-12-2013), r1 banshee (07-12-2013)
Old 07-12-2013, 03:48 PM
socalxj's Avatar
0/11 sssss2371
Go to The DD Box | DD Audio. I won't say anything bad about DD because they are a nice family ran bizz. But.....
Old 07-12-2013, 04:40 PM
BigBen's Avatar
0/11 sssss3006
Not quite sure what you're trying to point out here. I understand dd recommendations very well. They say to use 16" per cube. I agree that they will play lower with 16, but every designer here says to use 18-20. And then they complain about no lows. Coincidence?
Digital Designs Z2 Smerlington General Car Audio Discussion & Questions 5 11-08-2012 08:39 PM
Digital Designs VO-M8 mendezm9 Wanting to Buy (WTB) 1 02-14-2012 12:31 PM
Digital Designs General Feedback worstenemy453 General Car Audio Discussion & Questions 76 12-29-2011 07:48 PM
FS Digital Designs M4 mikeredam Mono Amplifiers 20 09-25-2011 07:01 PM
best subwoofer discusion.. shriver187 General Car Audio Discussion & Questions 56 06-04-2011 12:37 AM
