Bass knob clip lights? - Car Audio Classifieds!
Old 10-13-2013, 11:50 AM
dadydolas's Avatar
Loyal Member
0/11 sssss1744
Feedback Score: 22 reviews
Default Bass knob clip lights?
I see the trend with a lot of companies is moving towards having this feature. What is the general consensus as to how accurate these are?
Old 10-13-2013, 12:20 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Some have circuits to detect dc current, and some illuminate or flicker when near or at rail voltage... id set gains proper before trusting the clip light completely my self
Old 10-13-2013, 12:28 PM
dadydolas's Avatar
Loyal Member
0/11 sssss1744
I always try to do it that way but gain setting seems to be tricky. What I mean is I can set my gain on a 50hz tone with no clipping but then some music tracks will still cause clipping. I think because of the fact that music is recorded and mastered at so many different levels. Unless I am just doing something wrong.
Old 10-13-2013, 01:06 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
I'll be honest, I only pick amps that have clip lights, not saying they're accurate but it's nice to have an idea. And I don't spend as much time tuning an amp with the clip lights and I have yet to have a problem
xnewbx's Avatar
0/11 ssssss985
My clip light went off on my BC3500 at almost any volume...I once hooked up power a little JL 8" sub(150watt sub) and it still went off on it. Maybe mine was defective but a voltage meter would be 10x more useful than it.
Old 10-14-2013, 04:12 PM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
Please correct me if I'm wrong, but your electrical system also has a huge role in clipping. Bad ground = early clipping, same goes for excessive voltage drop. So it is theoretically possible to clip a 10k power block on a single 8, which will produce simply staggering amounts of smoke very quickly.
4 Fi SSD/Fi BTL soft parts 12s on AQ2200 at .5 daily;
Focal Polyglass comps/Crescendo CZ65s on JL 300/4;
Mechman 240, DieHard Platinum AGM & Optima Blue top, all KK 0 gauge runs and terminals.
Old 10-14-2013, 04:15 PM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
Were you overdriving the input stage, maybe?
Old 10-14-2013, 04:43 PM
0/11 sssss2094
Very lazy, I like your style.
The Following User Says Thank You to jackson81 For This Useful Post:
ENVI3D ONE (10-14-2013)
crescendo clip light does not work or first version bass clefs? shackleford General Car Audio Discussion & Questions 0 08-02-2013 10:15 PM
bass clef bass knob clip light not working shackleford (Crescendo) 2 08-02-2013 10:21 AM
bass gain knob or bass boost knob??? spl_robb General Car Audio Discussion & Questions 4 04-06-2013 11:29 PM
Sundown bass knob...$40? Looks like any cheap knob, wtf.. graham General Car Audio Discussion & Questions 5 02-17-2013 08:16 AM
