AQ2200 at 1/2 ohm - priceless. - Car Audio Classifieds!
Old 10-14-2013, 01:51 PM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
Default AQ2200 at 1/2 ohm - priceless.
I got bored over the weekend and made a fiberglass tub base for a new box. Four dual 1 ohm DVC Fi 12s on a AQ2200... Man, that amp was fun before on just two, as a 1 ohm load. Now running all four, 1/2 ohm load before the rise... It came alive. I feed it clean signal, electrical seems to be holding up well, never below 12.5 on idle, 12.8-13.1 driving, barely clipping. I love this little power box! Lol
4 Fi SSD/Fi BTL soft parts 12s on AQ2200 at .5 daily;
Focal Polyglass comps/Crescendo CZ65s on JL 300/4;
Mechman 240, DieHard Platinum AGM & Optima Blue top, all KK 0 gauge runs and terminals.
Old 10-14-2013, 01:53 PM
dirt101's Avatar
0/11 ssssss956
yeah generally when I cut the load in half and double my cone area I end up with a smile on my face too.
The Following 2 Users Say Thank You to dirt101 For This Useful Post:
slamica (10-14-2013), zrken1 (10-16-2013)
Old 10-14-2013, 03:04 PM
AlwaysLearning's Avatar
CACO Late Nite Tip
0/11 ssssss472
When i get more money i will be doing this as well plus much bigger amp
Old 10-14-2013, 04:03 PM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
Big smile. BIG. Next on the menu - all 4 of the same subs.
I guess I was not expecting the 1/2 ohm load to allow the amp full control of he subs, and anticipated massive heat issues.
I also guess I was wrong.
Old 10-15-2013, 12:29 AM
0/11 sssss5305
get your electrical up to par and you'd be happier. your voltage drops suck for what you have electrical wise...
Old 10-15-2013, 05:42 AM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
That's the worst of it that I've seen so far. Takes me about 15-20 minutes of going HAM to get there. However, I'm all ears - how do I "get it up to par?" Twin runs of 0 gauge are already in place, big three done, amp ground is direct to the rear battery, both AGMs are new, the alternator is, too. What would you suggest?
Old 10-15-2013, 07:22 AM
0/11 sssss1943
Youre using 2 different model subs?
Old 10-15-2013, 07:56 AM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
I'm...yeah. . I have had the SSDs laying around for a while, figured I'd throw them in along with the RE/Fi BL recones. Yeah, I know, not the optimal way, but it works.
Old 10-16-2013, 01:32 PM
Sykotic101's Avatar
Vanilla Gorilla
0/11 sssssss46
Ok, no advice other than the "get it up to par." Thanks, that really helps. I guess everyone's a critic, but only a few get to be directors.
The Following User Says Thank You to Sykotic101 For This Useful Post:
doug118 (10-16-2013)
Wiring two 4 ohm subs to 1 ohm, advantages? rideit General Car Audio Discussion & Questions 6 04-27-2012 02:49 PM
(2) Two Orion 2500d [2500x1 ohm] .5 ohm stable! Sonically_Sound Mono Amplifiers 20 11-17-2011 09:53 PM
[TRADED]mmats modded dhc1400.1 2000 rms @ 1 ohm & 0.5 ohm stable kickerfanatic Mono Amplifiers 10 02-07-2011 08:27 AM
AQ2200 safe at .5 ohm daily cato3 General Car Audio Discussion & Questions 12 11-22-2009 07:34 PM
AQ2200 below .5 ohm? sound_around General Car Audio Discussion & Questions 8 11-01-2009 12:26 AM
