New box and Wood Advice - Car Audio Classifieds!
Old 10-15-2013, 07:32 AM
tntahoe's Avatar
0/11 sssss1196
Default New box and Wood Advice
OK I finally picked up me another 12 which brings my total to 3. I have 3 Obsidian Audio 12s dual 4 ohm and a Crescendo 3kwp to power them. This will be in the trunk of my Dodge Charger. This will be a trunk build and the only way I can fit the subs in there would be subs upward, but not really sure on which direction to face my port, Im thinking of firing it back towards the trunk. Also I have 6x9s in the rear deck which have a black insulation material covering the bottom of them. Should I remove this material and would my 6x9s be damaged by the subs? Now on to the wood, I stopped in Home Depot yesterday and I decided to try some wood other than mdf for once. There were 4 different types of plywood that struck my interest: hardwood maple, birch hardwood, oak hardwood, and sandeply. The maple is $41 while the rest are $47, they all look fairly similar to me, what do you all think? Also is it beneficial to double layer the baffle if the subs are facing upwards, would just bracing the inside make more sense?
here are the woods:
http://www.homedepot.com/p/Unbranded...9#.Ul05h1CsjTo
http://www.homedepot.com/p/3-4-in-x-...9#.Ul05kFCsjTo
http://www.homedepot.com/p/Unbranded...0#.Ul05nFCsjTo
Old 10-15-2013, 07:53 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
I would go with the birch ply as I have always had good luck with it. Also make sure its atleast like 11ply +. I would think the 6x9s would be ok even with the cloth like tray removed. I can tell you from experience that you will gain a little height for the enclosure by removing it. Good luck with the build man.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 10-15-2013, 08:13 AM
tntahoe's Avatar
0/11 sssss1196
None of the plywoods they have are 11 ply most of it looks to be around 5-7 ply.
Old 10-15-2013, 08:37 AM
1loudmonte's Avatar
0/11 sssss2167
I wouldnt use that then. Do you have any cabinet shops around you. I get my 12 ply baltic birch for 37 a sheet from the cabinet shop near my house.
Old 10-15-2013, 08:55 AM
0/11 sssss1475
I seen subs up port forward work well. Port back will destroy the trunk lid n rattle like a bish. I agree on the wood from Lowes or home depot isn't what u want. 11 ply is usually sold in 4x4 sheets where I live. Never seen 4x8 11 ply. It's worth the extra $ in saw dust alone, mdf sucks to work with.
Old 10-15-2013, 09:09 AM
tntahoe's Avatar
0/11 sssss1196
What's the need for so many layers?
Sent from my HTC One using Tapatalk 2
Old 10-15-2013, 09:32 AM
0/11 ssssss285
all of the "birch" and the other cabinet grade stuff at home depot is actually a cheaper type of hardwood with a birch, oak, ect veneer. I get my 11 ply birch 5 x 10 sheets from a wholesaler but have made several hundred enclosures out of the 5 ply stuff from home depot and I nor any of my customers have complained about it being inferior. Sure it's definitely not at strong or dense at the 11 ply but it works just fine.
Old 10-15-2013, 09:43 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
i would use the birch. i double baffle all my boxes and have never had to do internal bracing.
My game is legit,
Old 10-15-2013, 10:25 AM
tntahoe's Avatar
0/11 sssss1196
How would double baffle work when it's facing up, I would flush mount the subs.
Box advice! CEGrizzly General Car Audio Discussion & Questions 13 11-13-2012 02:07 PM
Anyone sell JUST cut pieces of wood for box? fyerbyrd22 Enclosure Discussion & Design Construction Help 27 08-03-2012 01:12 PM
box wood thickness 423bass Enclosure Discussion & Design Construction Help 6 03-19-2012 11:37 PM
Wood for box?? Birch or mdf? Bubba906 General Car Audio Discussion & Questions 6 06-14-2011 11:10 AM
can i build sub box with hard wood instead of mdf? armyranger3858 Enclosure Discussion & Design Construction Help 0 02-03-2011 09:26 PM
