Center Console Build - Car Audio Classifieds!
Old 10-15-2013, 03:33 PM
0/11 sssssss40
Default Center Console Build
Hello all,
Awhile back I was looking at putting some 10's under the back seat of a 99 ram, but long story short it never happened. I am installing gauges and rocker switches into my truck and have decided I want to make a center console sub box running a sealed chamber and a ported chamber. I am looking at Fi BL 10 facing rear of the cab with two 3 inch aero ports facing rear also in a 1.893 net cuft chamber. The other chamber will be .42 net cuft for a Fi Q 10. I eventually want to run both subs on one amp. I was pretty attracted to the Alpine MRX- M240 because I must do one sub at a time because of college and finances. This would allow me to run the sealed or ported sub by itself on that amp as well as being to rewire both in the future. Looking at getting dual 2 ohms to wire the first sub at 4 ohms to run 1500 RMS and then when I get second, wiring at 2 ohms to receive 2400 RMS. Does this sound ok to you guys, the box will be 3/4 MDF with a coat of fiberglass resin wrapped in leather to match truck seats with a plush pleated arm rest on top.
I have already done big three and will be adding two more AGM batteries. I am running stock alternator (either 117 or 136)
Any input or advice is more than welcome, Thank you
Old 10-16-2013, 08:26 AM
0/11 sssssss40
Anyone? If nobody believes me I can take pictures of drawings mdf and a missing center console
Old 10-16-2013, 09:56 AM
0/11 ssssss102
Make a badass fourth order and it will sound just as good as a sealed box. Those subs should be easy enough to find specs for someone to help with a SQL box.
Old 10-16-2013, 10:14 AM
dirt101's Avatar
0/11 ssssss956
the problem with your setup is using two different subs in two different boxes. Why? Sounds like you want fi so I would just run two fi q10s in a shared chamber about 2cu tuned around 32.
The Following User Says Thank You to dirt101 For This Useful Post:
05pontiac08 (10-16-2013)
Old 10-16-2013, 10:54 AM
0/11 sssssss40
Well the reason for doing a sealed/ported box is I want the punch and clarity of a sealed box as well as being able to hit the lows hard. I know this would be easily accomplished by building a bandpass, but I have nowhere near the room. I have 3 feet of length total. I have 19 inches of height and 14.5 inches of width max. The other issue is I need to drop te box down at about 24 inches in able to use my cup holders. That drops the height of the remaining 12 inches to 4 inches tall
0/11 sssssss40
I would not mind using two fi q series if it would make it easier
Old 10-16-2013, 11:00 AM
0/11 sssssss40
I have pictures of the plans but I'm on my iPhone an cannot figure out how to upload
Old 10-16-2013, 11:55 AM
0/11 sssssss40
I've been thinking about what you said dirt and as long as they will hit clear and good do you think they would be ok facing opposite directions?
Old 10-16-2013, 12:17 PM
0/11 ssssss247
You don't have to have sealed for "punch and clarity". I'd sell one or the other and buy one to match. A properly designed ported enclosure will do everything you want.
Old 10-16-2013, 12:23 PM
dirt101's Avatar
0/11 ssssss956
I would really try to keep them on the same plane if possible
Decent center console build help LyferXB9s Enclosure Discussion & Design Construction Help 7 09-02-2013 09:44 PM
Small build for under the center console. oxsign Build Logs 0 03-09-2013 03:12 PM
subs for center console build please help southautorecon General Car Audio Discussion & Questions 7 02-17-2013 03:37 PM
center console build help anyone?? buttphacekilla General Car Audio Discussion & Questions 68 01-20-2012 09:15 PM
2006 CRV center console build! andrewtexas123 Build Logs 25 06-25-2010 08:22 PM
