Idler pulley replacements - Car Audio Classifieds!
Old 10-15-2013, 11:27 PM
beatnbronco's Avatar
0/11 sssss2284
Default Idler pulley replacements
What is it that I see in most multi alternator setups where idler pulleys are replaced with? They look like sealed bearings but want to make sure before I purchase. A link would be helpful too. Thanks
Sent from my SPH-L710 using Tapatalk
Old 10-16-2013, 04:44 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Those pictured are a high temp iiidler that's just really small to make it simpler for placement vs a bigger 3"+ idler...any idler should work as long as its a reliable brand
Old 10-16-2013, 05:11 AM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
Width and bearing I.D. are the main importance of consideration
it makes since that if u add an alternator it will add resistants make your MPG go down but i dont see how turning up your volume adds more resistants.
SENSE RESISTANCE
Perhaps a mod could change it to "Massivespfail"?
Old 10-16-2013, 11:24 AM
slowpoke's Avatar
newbie forever
0/11 sssss1160
in my experience with boosted applications the smaller the pulley's the easier that the belt system tracks. by reducing the pulley diameter your reducing drag weight that the belt system has to contend with. if you can find them, then aluminum pulleys(yes some shops make aluminum idler pulley's) would be the best. make sure they have been properly hardened though. some shops will kick out raw pulleys and they just get chewed up after a year or so.
150db loud redneck
Old 10-16-2013, 02:17 PM
0/11 sssss2284
Thanks..found some today..now to figuring out this puzzle
custom alternator idler pulley for 94-97 accord Kreepn Sound Deadening & Fabrication 3 01-29-2013 11:16 PM
Small Idler Pulleys for Second alt bracket? taylorpro General Car Audio Discussion & Questions 37 06-03-2012 02:45 PM
Has My Replacements Been Shipped? ctmaudi (Crescendo) 3 08-04-2011 07:48 PM
HID Kits and replacements HiloDB1 General Car Audio Discussion & Questions 2 08-06-2010 03:18 PM
pa crossover replacements? tymoto21 General Car Audio Discussion & Questions 0 03-02-2010 03:40 PM
