Will this cause voltage lost?? - Car Audio Classifieds!
Old 10-15-2013, 11:46 PM
Twitney181's Avatar
0/11 ssssss591
Default Will this cause voltage lost??
So my 50ft if execution audio 0/1 gauge will be here tomorrow, and I'm wondering if the way I have this set up is going to cause any issues with current flow, i will be upgrading to 2 runs of execution rather then one run of audio pipe, I have my rear battery (xs xp3000) to my wal mart deep cycle by way of that black post adapter. I have it that way so when I charge my batteries I can unhook them with the wing nut and charge them with ease (since they are different types of batteries) equipment being used is a FI sp4 15 on a dd m3a at .7ohm and a sound stream tx4.560. Which are both connected directly to the rear batt.
Also, if you get this far, is there a big difference in ring terminals? Will the local stereo shop ones suffice? Besides the jacked up price.
Old 10-15-2013, 11:50 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Should be fine. Provided the terminals are decent
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 10-16-2013, 12:33 AM
Twitney181's Avatar
0/11 ssssss591
I guess if I'm having unreasonable drop in that back I can swap posts with the other wires and see if that solves it. Is there gonna be any noticeable difference if I just get whatever ring terminals (0/1) tat my local shop has versus ordering like knu or something online?
Old 10-16-2013, 12:35 AM
Team SPL Farms
0/11 sssss5000
Probably not much. Could go to napa or something and get 1/0 copper terms too if the others seem suspect.
Kenwood ddx470
Old 10-16-2013, 01:07 AM
OldsSafari's Avatar
0/11 sssssss29
That or your local trucking parts store, they deal with 1/0 more often than some napa/car parts stores and you may have more luck.
Use copper terminals, and make sure you crimp/solder them on good and you won't have a problem. Preferably I would solder them on, but as long as you do a good proper crimp in it you won't notice much of a difference.
Resident Geeky Grease Monkey...
Instagram
@nightcrusin24 #wagonwagoff #becauselandyacht
Old 10-16-2013, 11:13 AM
0/11 sssss3526
Affixing them firmly is as important as terminal itself. Loose connections are known for issues.
need help, im lost 05 obs General Car Audio Discussion & Questions 10 01-30-2013 12:21 AM
Fed ex lost my excessive amperage alternator and voltage regulator rhesketh General Car Audio Discussion & Questions 137 10-04-2012 08:02 PM
so lost Im loud256 General Car Audio Discussion & Questions 6 04-04-2012 01:36 PM
:( I just lost... 92K1500 Off Topic Chat 18 09-04-2010 03:44 PM
lost dphat Enclosure Discussion & Design Construction Help 8 09-04-2010 06:41 AM
