Dual Alt setup for KIA possible? - Car Audio Classifieds!
Old 10-17-2013, 12:12 PM
Haelmuscle's Avatar
0/11 sssss1819
Unhappy Dual Alt setup for KIA possible?
Hi Guys,
Want to know if there is any idea to do dual alternator setup in KIA Optima 2012
Thank you guys,
Best Regards.
Old 10-17-2013, 12:39 PM
tacomaguy1's Avatar
0/11 sssss4401
I'm sure it is....will need to fabricate you're own bracket i'm sure
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 10-17-2013, 12:41 PM
Haelmuscle's Avatar
0/11 sssss1819
Thank you BRO.
Anyone can do bracket for me ?
I will pay him what he wants!
Best Regards.
Old 10-17-2013, 12:52 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
If you got the money..anything is possible..
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 10-17-2013, 12:57 PM
btsteinb's Avatar
0/11 sssss3573
We arent gonna be much help seeing as you are in saudi arabia.
Sent from my PC36100 using Tapatalk 2
Old 10-17-2013, 01:13 PM
tacomaguy1's Avatar
0/11 sssss4401
Originally Posted by Haelmuscle View Post
Thank you BRO.
Best Regards.
There has to be a fabricator or someone that works with metal where you're at....check out some local shops
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
The Following User Says Thank You to tacomaguy1 For This Useful Post:
Haelmuscle (10-19-2013)
Old 10-17-2013, 01:59 PM
Haelmuscle's Avatar
0/11 sssss1819
I tried here but they are scared doing custom things!
I have the money for sure I just want the fabricator to made that bracket and send it to me and I will pay him what he wants and I will pay the shipping costs!
I need someone can fabricate the bracket on any optima 2011-2013 and then send it!
Thank you guys, Appreciate it.
Best Regards.
Old 10-17-2013, 02:09 PM
99Bonney's Avatar
0/11 sssss6246
Even if you fit a dual alt kit on there, I doubt your engine is going to handle it well. What size engine do you have? If it's a 4cyl you can forget it, v6 possibly but you still probably won't get full power out of your alts.
I'd say your better off just getting quality wiring/batteries to be as efficient as possible.
Good luck
The Following User Says Thank You to 99Bonney For This Useful Post:
Old 10-17-2013, 02:29 PM
Haelmuscle's Avatar
0/11 sssss1819
Thank you BRO,
It's i4 2.0l hahahahahahahahahaha.
I did alternator upgrade (rewinded) it came with smaller pulley and was slipping and putting stress on the tensioner pulley due to the smaller sized pulley is harder to turn!
Got 13.8 at idle instead of 14.3 (Car warmed) when I rev it I get 14.1 upgraded and 14.3 stock unit!
I was running crescendo BC3500 at 1ohm stock front battery for testing without rear batteries at all,
I hit 11ish lowest! When I swapped the alternator by the upgraded one I had 10volts lowest with upgraded battery under the hood !
I had BIG 3 on both alternators and the stock unit outperformed the upgraded unit.
Since then I've been upset and hated my car!
I paid 500 $ for that alternator, What a waste!
I need someone can bring back my happiness in this life by manufacturing powerful alternator for my application!
I wish that guy refund me that alternator I bought.
Big thanks guys, Best Regards.
Old 10-17-2013, 02:51 PM
99Bonney's Avatar
0/11 sssss6246
I'm not an alternator tech kind've guy but you're going to be better off with a lower amperage alternator. I had a DC 270xp on my 4cyl engine and it def was able to bog my engine down. Your best bet would be to call DC Power Engineering and see if they make a HO Alt for your vehicle. Usually if they don't, either will Mechman or Singer but you could at least give them a call too.
I wouldn't do a rewind, they seem to turn out like shit, as you found out.. Lol.
Worse case run your stock alt since it's obviously running better than your "upgrade" and get a decent electrical. 3500w is doable with a nice battery reserve but you won't be playing for long periods of time with that alt.
dual alt setup 1loudmonte General Car Audio Discussion & Questions 6 09-25-2013 10:48 PM
Civic dual alt setup cookiemonster Build Logs 4 02-29-2012 05:35 PM
Dual Alt Setup Question? younggunzbass01 General Car Audio Discussion & Questions 9 06-26-2011 05:54 PM
Dual alt setup?? RetroAudioInc General Car Audio Discussion & Questions 8 03-19-2010 02:23 PM
V8 S10 Dual Alt Setup Gavriley2007 General Car Audio Discussion & Questions 5 10-20-2009 06:32 AM
