Mmats 15's for a 4th order. Worth using? - Car Audio Classifieds!
Old 10-17-2013, 07:32 PM
doug118's Avatar
0/11 sssss4674
Default Mmats 15's for a 4th order. Worth using?
A friend of mine said he'd like me borrow his 4 Mmats Procast 15's for a temporary build. I want to try building another 4th order after my first one was a miserable fail lol. Has anyone used or seen these subs in action? They look like a SA-15 but use a 3" aluminum coil. I was thinking about doing 1.5 sealed and 3 ported since I think that's the very most I can squeeze out, IF I can even get that much. Would it be better to use only 3 subs and use a bigger ratio? Links to the sub are below. They are listed as the P3.0 in the specs link
Procast
http://www.gommats.com/wp-content/up...heet-20112.pdf
07 Impala SS 4th order for 2 15's Whoodwhooker Build Logs 111 01-22-2014 07:51 AM
Need Help with 4th order for 2 SA-15's bigdogjk (Sundown Audio) 3 01-08-2012 04:41 AM
4th order for 2 SA-15's bigdogjk Enclosure Discussion & Design Construction Help 0 01-07-2012 06:52 PM
2 12" MMATS Juggernauts in a 4th Order. LEN671 Enclosure Discussion & Design Construction Help 18 06-08-2011 12:09 PM
2 dc lvl 2 15's 4th order JAYARE2007MAG Enclosure Discussion & Design Construction Help 2 05-22-2011 11:21 PM
