Dual 0.5 subwoofer options - Car Audio Classifieds!
Old 10-20-2013, 12:14 PM
Shawn106's Avatar
0/11 ssssss190
Default Dual 0.5 subwoofer options
Hello everybody. I need your help. What 12's are available in dual 0.5 ohm? I know the DD 3500's and 9500's are. Are there any others that are available in dual 0.5 ohm? I need to do some research for my 4 12 wall build, and I don't want to blow a wad of cash for DD if I don't have to!!!!
Ridiculous Soundz!!!!!
Need I say more?
Old 10-20-2013, 12:18 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
I am sure PSI could get something for you.
I would try DC, Sundown, FI just to see if they can. They all build their own subs so it would be a possibility.
Old 10-20-2013, 12:57 PM
Matt3824's Avatar
0/11 sssss3754
I just recently purchased a Tantric HDD 12 in Dual 0.5 Ohm.
Old 10-20-2013, 01:37 PM
0/11 ssssss816
Feedback Score: 22 reviews
B2 audio also offers .5 ohm
Old 10-20-2013, 02:30 PM
robman's Avatar
DC AUDIO!!!
0/11 ssssss427
mind me asking what you want you're final ohm load to be? 1 amp, 2amps?
2000 Ford Taurus
2- Dc Audio level 5 15's
Dc Audio 7.5k
3- Xs Power D3100's
Loudest number- 150.6
Old 10-20-2013, 04:17 PM
Shawn106's Avatar
0/11 ssssss190
@Robman I will be using four amps. And they are stable to 0.5 ohm and strappable.
Need I say more?
Old 10-20-2013, 05:04 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Incriminator audio http://www.incriminatoraudio.com/ind...subwoofer.html
Dual 0.35, Dual 0.50, Dual 1.0, Dual 2.0
Old 10-20-2013, 05:53 PM
0/11 ssssss543
With one amp per sub you will only be able to wire at 1 or .25 not .5. Running 1ohm each is fine, you might be able to burp at .25 if you want to.
Old 10-20-2013, 06:51 PM
Shawn106's Avatar
0/11 ssssss190
@dbjunior, I will series/parallel 2 subs which will give me.50 and that will give me .25 at each strapped amp.My rise is times 3 based upon my box and DD 9500's. So each amp will see .75. And since they are .50 ohm stable, that is sweet to me! If I parallel/parallel, then that would be .125 times 3 which is .375(danger!!!). So series/parallel it is!
Need I say more?
Old 10-20-2013, 07:10 PM
Skip01's Avatar
Ladies MAN
0/11 sssss5551
Why not 2 D2s for .5 than strapped to .25 each amp?
Youtube VIDz :
Home theater subwoofer options art1618 General Home Audio/Video 15 06-17-2013 10:41 PM
Weird Subwoofer Options...help? shaun47 General Car Audio Discussion & Questions 19 04-25-2013 11:48 AM
Six 15"s subwoofer wiring options. Mnorwood01 General Car Audio Discussion & Questions 6 11-19-2012 07:57 PM
Your Thoughs on these subwoofer options... doc289 General Car Audio Discussion & Questions 22 01-20-2012 06:20 PM
Subwoofer options stevenminix General Car Audio Discussion & Questions 3 04-10-2011 03:53 AM
