Removable baffle. Best way to make one? - Car Audio Classifieds!
Old 10-20-2013, 04:10 PM
doug118's Avatar
0/11 sssss4674
Default Removable baffle. Best way to make one?
Building a 4th order this week and I'd like to make the loading wall removable. What would be the best way to do it, making sure its properly sealed every time? I figured I'd use angle iron and bolts to bolt the baffle on but want to be 100% sure it'll have a perfect seal
Old 10-20-2013, 04:24 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
weatherstriping?
My game is legit,
Old 10-20-2013, 04:32 PM
0/11 ssssss266
you could lay out a bead of silicone on the perimeter and allow it to dry for 24 hours.
once dry then you can assemble the unit and the silicone will create a seal that can be removed.
Old 10-20-2013, 04:36 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
Originally Posted by BallzFast View Post
weatherstriping?
I use some expensive stuff I get from work...it works great...
On another note, I have a front baffle/port for sale. Its made from 1/4" 304 Stainless Steel. Its hard to explain but I'll be posting a listing for it a little later on tonight when my pics upload.
it makes since that if u add an alternator it will add resistants make your MPG go down but i dont see how turning up your volume adds more resistants.
SENSE RESISTANCE
Perhaps a mod could change it to "Massivespfail"?
Old 10-20-2013, 10:34 PM
doug118's Avatar
0/11 sssss4674
I guess I'll just go by home depot and look around for thick rubber weather stripping
Old 10-20-2013, 10:46 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
i use bolts and silicone
removable port help aqspud15 Enclosure Discussion & Design Construction Help 6 03-28-2012 04:53 PM
Removable Baffle and other crazy ideas SpeedEuphoria Enclosure Discussion & Design Construction Help 11 05-18-2011 01:11 PM
removable battery, best way to do it? Anton Miller General Car Audio Discussion & Questions 1 04-28-2010 09:45 PM
how to make a removable top assembly..... DonH General Car Audio Discussion & Questions 14 12-14-2009 02:09 PM
Removable Ports? dak446 General Car Audio Discussion & Questions 19 09-24-2009 04:21 PM
