Knukonceptz 1/0 to 4 ga reducer review - Car Audio Classifieds!
Old 10-20-2013, 06:41 PM
0/11 ssssss252
Default Knukonceptz 1/0 to 4 ga reducer review
I wasnt real happy with my purchase of these so I thought I would share why. Purchased for some testing of an amp with 4ga inputs but turned out they didn't fit.
Based on this little snipet of a chart I found on wiki AWG standards show 4g to be 5.189. If I understand correctly car audio wire is about 10% larger due to the air space created by the stands so lets call it 5.7 mm.
When they didnt fit i measured the amp...
Cool, no worries there its a little bit oversize, as it should be to allow room for the wire be inserted.
Now I measure the inputs...
To top it off the 1/0 knu wire is a VERY tight fit. Not that easy to get them on.
Old 10-20-2013, 07:02 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Do you have another amp with 4 ga. inputs? the ap amps seem to have smaller inputs than most amps, the ap CCA 4ga wire dont even fit the ap mini amps
Old 10-20-2013, 07:03 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
i dont think the chart you have is completely accurate. i could be wrong tho
TM adapters are .315" or 7.9 mm, an they are loose in a apsm mini 1500
Old 10-20-2013, 07:12 PM
0/11 ssssss252
I dont I dont even have any 4ga wire. I tried to figure all this out before posting a negative review but it still looks to me that the post is much larger than it should be. Going off awg wire standards was about the best path I would take. I also took a look at Knu's 4g specs on their site and it is listed at 8mm as compared to this 8.39 for the post. We all know knu wire to be over-sized and this is even larger than that.
For me not that big of a deal, grabbed the grinder and 5 min later problem fixed but I'm going to guess most people dont want to do that.
That is the apsm mini 1500 thats in the pic so the 7.9 mm shouldn't fit either.
Heres another chart from another site as an additional reference. Still need to add 10% but even with that were quite a bit off.
Old 10-20-2013, 07:32 PM
sthrnbumpn's Avatar
0/11 sssss2961
maybe ap had an input size change on their amps
Old 10-20-2013, 07:34 PM
0/11 ssssss252
interesting. Do you have a caliper you can check the inside of your terminal?
Old 10-20-2013, 07:35 PM
sthrnbumpn's Avatar
0/11 sssss2961
im not trying to discredit you.... its just that your numbers got me to wondering.
Old 10-20-2013, 07:39 PM
sthrnbumpn's Avatar
0/11 sssss2961
no calipers at home, but their obviously larger than 7.9mm
Old 10-20-2013, 08:13 PM
0/11 ssssss252
No worries. Any input is always appreciated. If anything people now know the exact size and can measure before they buy
Would a reducer cause a bottle neck? KingPen General Car Audio Discussion & Questions 7 10-14-2013 08:54 PM
1/0 to 4 gauge offset reducer morbid1488 Toolmaker Price Quote Section 0 03-11-2013 12:48 PM
Reducer 4ga - 8 ga nismos14 Toolmaker Price Quote Section 0 11-30-2011 02:11 PM
0/4 reducer pics Pieper General Car Audio Discussion & Questions 2 11-13-2010 08:55 PM
1/0 to 4ga reducer madmat Wanting to Buy (WTB) 11 07-11-2009 02:46 PM
