Electrical help or advice needed - Car Audio Classifieds!
Old 10-21-2013, 09:12 PM
staytrue27's Avatar
0/11 sssssss74
Default Electrical help or advice needed
I drew up a diagram of the wiring and batteries I plan to put in my Tahoe soon. Pretty sure it's rite or close to rite. But I'm doubting myself and really wanna make sure I'm rite before I start my install. Once I make sure my wiring is rite then ill figure out were each fuse goes and what size to use. I wanna go ahead thank whoever takes the time to give me any input, advice, suggestion or hate. I appreciate it. Here's the diagram, oh yea and it's all 1/0 OFC wire except the 2 small amps.
[/IMG]
Old 10-21-2013, 09:13 PM
staytrue27's Avatar
0/11 sssssss74
[IMG][/IMG]
Old 10-21-2013, 09:16 PM
staytrue27's Avatar
0/11 sssssss74
Another question,.... Do I need the long negatives? As long as I ground everything good I shouldn't need the long neg's rite?
Old 10-21-2013, 09:21 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
I would get rid of the negative distro block and ground the amps directly to the frame or best grounding avaliable. From what I can see the battery wiring is good.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 10-21-2013, 09:25 PM
staytrue27's Avatar
0/11 sssssss74
Even if I was gonna drill a hole and use a grummit (whatever u call it) and have 1 or 2 runs of 1/0 awg to the chassis grounding the busbar?
Old 10-21-2013, 09:26 PM
staytrue27's Avatar
0/11 sssssss74
If I ground each amp and the batteries to the chassis that will require a much bigger hole. But if it's the best way then it's what I have to do.
Old 10-21-2013, 09:32 PM
staytrue27's Avatar
0/11 sssssss74
I just noticed, on the diagram there's suppose to be a green line (representing negative) from battery #5 to the bus bar #7. Hope I didn't just confuse everything
Old 10-21-2013, 09:41 PM
staytrue27's Avatar
0/11 sssssss74
If there's anybody that wants to chime in on were some fuses need to go that be cool. But I'm gonna work on that next and maybe add to this thread or start a new one.
1loudmonte's Avatar
0/11 sssss2167
You can ground the amps to the battery there is nothing wrong with that, I prefer to ground directly to the frame if possible.
The Following User Says Thank You to 1loudmonte For This Useful Post:
staytrue27 (10-21-2013)
Old 10-21-2013, 09:47 PM
staytrue27's Avatar
0/11 sssssss74
Yea, grounding to the frame/chassis is the plan. Thanks
SQ newb - advice needed Munny Sound Quality Area 14 09-30-2013 03:25 PM
electrical needed for AQ3500? califaplayer707 General Car Audio Discussion & Questions 24 04-26-2013 11:15 AM
HO alt needed + wire advice needed AllenH427 General Car Audio Discussion & Questions 25 11-08-2010 10:04 AM
Aeroport Advice Needed strpperpolef150 Enclosure Discussion & Design Construction Help 122 09-07-2009 08:31 PM
Guitar Advice needed mytyeerinpie Off Topic Chat 21 05-18-2009 08:27 AM
