NS1 or kicker warhorse - Car Audio Classifieds!
Old 10-24-2013, 12:26 PM
0/11 ssssss106
Default NS1 or kicker warhorse
which one would you guys pick a kicker warhorse or an ns1..ive heard mixed reviews about the warhorse saying its great then other people saying it does not do the 10k it claims..not too sure at the moment which amp is more powerful any one had any experience with both
Old 10-24-2013, 12:46 PM
Wes669's Avatar
Street light banger
0/11 sssss1869
It depends. The specs say the warhorse is two ohm stable, and if you're going to drop the money on something like that might as well get the sundown.
'02 trailblazer
4 c2 threatcon 2 12s
Audioque 2200
Zapco 150.2
4 kinetic 1800s
The Following User Says Thank You to Wes669 For This Useful Post:
leonfowler (10-24-2013)
Old 10-24-2013, 12:49 PM
TheJesus's Avatar
Yawning
0/11 sssss1921
You have to understand the warhorse isn't a typical amp design, it has to be wired a specific way. I know BumpinBuick on here could tell you more.
I'd recommend the NS-1 personally out of the two, but there are more amps to choose from.
Sent from my SGH-M919 using Tapatalk
I used to have that walled Challenger, then it got totaled...
2015 IASCA Welterweight Champion and Record Holder - 156.0 Avg (No door blockers)
2016 IASCA Welterweight Record Holder - 157.7 Avg (Door blockers used)
Team Sundown Audio & Fullriver Faction Member
Old 10-24-2013, 01:04 PM
0/11 ssssss106
i have an ns1 already and i wanted to see if me getting a warhorse would be an upgrade power wise and thank you for your replies guys
Old 10-24-2013, 01:06 PM
0/11 ssssss106
thats is very true i wouldnt want to waste my money on something that wouldnt be worth it thank you for your help
Old 10-24-2013, 01:14 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
You already have a ns1. Buy another two would be a lot more power then a warhorse plus if the warhorse ever blows who will fix it. Db-r is great for fixing sundown amps. If you need more power switch to 16 or 18 volt electrical
The Following User Says Thank You to djscrubb For This Useful Post:
Old 10-24-2013, 01:16 PM
0/11 ssssss106
ok man thanks you make alot of good points i think i willl just keep my ns1 then after all i just needed some reassurance to make sure i was making the right choice
Old 10-24-2013, 08:42 PM
perfectcircle's Avatar
0/11 ssssss236
i have two warhorses and can chime in. its a very effecient amp and can run on extremely low voltage and still put out rated power. i've never had mine clamped, but it does around rated i believe. the biggest problem is size and wiring options. it has to have an actual dual 2 load. they call it a push pull. it uses the positive 2 ohm to either push or pull the sub. and the negative to do the opposite. there are two seperate inputs one for negative and one for positve. you can run two dual 4s or one dual 2 or 4 dual 2's. you can research wiring options. i'm running a dual 2 z to each. hope that makes a little sense.
Highs: DD Bullet tweets
Mids: 4 PPI 8", 4 DD 6 1/2's, 4 AQ 6 1/2's with several SS amps
Lows: 2 DD Z18's with 2 Kicker Warhorses
Mechman 300 + Excessive Amperage 275
Kinetik hc2000, Kinetik hc2400, 2 Cactus 9000's
The Following User Says Thank You to perfectcircle For This Useful Post:
leonfowler (10-25-2013)
Old 10-25-2013, 12:36 PM
0/11 ssssss106
thank you it does i heard you have to really know how the amp works before u hook it up
Kicker Warhorse nicyousuckk eBay 2 12-08-2011 02:14 PM
Kicker warhorse nicyousuckk Mono Amplifiers 61 11-09-2011 09:20 AM
Kicker Warhorse goodyearj General Car Audio Discussion & Questions 4 06-26-2011 05:59 PM
Kicker Warhorse rmzsuzuki89 Mono Amplifiers 40 04-29-2011 11:40 AM
Kicker warhorse Loudman General Automotive Chat 72 11-28-2010 05:06 PM
