Trunk Drawer for Amp Rack? - Car Audio Classifieds!
Old 10-24-2013, 04:38 PM
dag79's Avatar
0/11 sssssss64
Default Trunk Drawer for Amp Rack?
Anyone know of a tutorial or have previous experience to share on how to install a 30"W X 12"D X 4"H slide out drawer in the trunk? It will serve as a amp rack for my two amps. My aim is to have the amps hidden yet easy to access. I would also like to use a 12V. linear actuator. Any pointers will be appreciated.
Old 10-24-2013, 04:59 PM
0/11 ssssss943
Just put a three drawer dresser in your trunk. Top drawer for your subs, middle drawer for your amps, and bottom drawer for your weed. Problem solved
The Following User Says Thank You to russhay78 For This Useful Post:
baseballin (10-24-2013)
Old 10-24-2013, 05:16 PM
Twitney181's Avatar
0/11 ssssss591
Lemme find some pics of my old slide out from my old build.
Old 10-24-2013, 05:23 PM
Twitney181's Avatar
0/11 ssssss591
This is from my old set up, I used the runners off an old computer desk, but you can get em at Home Depot for cheap. I screwed the runners onto some Mdf so I could mount them to the box, then I put a little lock on it to keep it from sliding around (didn't need the lock tho, had its own locking) and then put rubber boots under the amps to help with the vibration since it was on the box.
Old 10-24-2013, 05:40 PM
Austin175's Avatar
0/11 sssss4224
Hella clean man
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 10-24-2013, 08:26 PM
dag79's Avatar
0/11 sssssss64
That's a nice setup man. That gives me a starting pointI have no idea where I would mount the actuator. Any suggestions?
Old 10-25-2013, 12:43 AM
Twitney181's Avatar
0/11 ssssss591
I have no idea haha
Old 10-25-2013, 11:14 AM
0/11 ssssss396
on the underside of the deck probably
1998 Civic EX Coupe
Pioneer 7200HD
Incriminator Audio 6.4
B2 ES6.1i Tweeters & Silver Flute 6.5's
Crescendo BC2000
Tantric HDD12 coming soon
Amp rack? A.Smo General Car Audio Discussion & Questions 17 06-21-2012 12:42 PM
First amp rack. djspl General Car Audio Discussion & Questions 1 08-24-2011 03:47 PM
HD amp rack ?'s onebadmonte General Car Audio Discussion & Questions 1 02-19-2011 10:34 PM
Patrick's CACO amp rack and trunk panel ideas Patrick Simmons Enclosure Discussion & Design Construction Help 31 01-18-2009 05:19 PM
Need Ideas for Amp Rack and Battery Rack! BassikInstincts General Car Audio Discussion & Questions 8 01-15-2009 10:36 AM
