What to do after amp gains are oscope/DMM set? - Car Audio Classifieds!
Old 10-25-2013, 08:52 PM
0/11 ssssss522
Question What to do after amp gains are oscope/DMM set?
I have properly set the gains on my m1 b2 amp but what are u supposed to do after u adjust all the rest of your settings from flat ( I have a audio control eqs between my headpiece and amp, what should I set it to or should I just test again running through a normal set of listening preferences?)
Old 10-26-2013, 12:02 PM
0/11 ssssss522
Does anyone have anything? Any past experiences! Any input would be greatly appreciated
Old 10-26-2013, 12:03 PM
0/11 ssssss522
Thanks again...
Old 10-26-2013, 12:04 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
I'd set your eq where you want it for all of your other amps/speakers first. Then set the sub amp gains.
-Youtube Channel
Old 10-26-2013, 12:11 PM
ChevyBoy95's Avatar
You have no Declue
0/11 ssssss773
if you set your gains with a flat EQ, then boost something or even minor adjust something up, it will basically throw you into clipping very quickly. Put your EQ to how you would have it at full tilt, then set your gains.
Old 10-26-2013, 12:17 PM
SPL Distribution Owner
0/11 sssss2983
You shouldn't ever have to boost an EQ.
But if you do boost any part of the EQ, you need to confirm it doesn't amplify the signal past where you set the gains to.
Old 10-26-2013, 01:13 PM
0/11 ssssss522
So then I should set my eqs to my liking hooked up to my amp (b2 m1s)then adjust the the amp accordingly? Thanks man !
Old 10-26-2013, 04:03 PM
0/11 ssssss522
Well with a head piece that is only putting out 1.5 volts on the output has forced me to damn near excellerate the gains to almost the max to bring my eqs to life
Old 10-26-2013, 04:05 PM
0/11 ssssss522
So should I set the gains on my amp with my eqs hooked up & signal to the amp?
Old 10-26-2013, 04:10 PM
0/11 sssss2983
Yes but you should it flat and then use an rta to adjust.
Any other means is just shooting in the dark.
Tags
b2 audio, dmm, eqs, m1s, oscope
How to set gains with DMM and strapped amps, and V loss question ImBob General Car Audio Discussion & Questions 7 05-02-2013 08:46 PM
I need a DMM to test RCA voltage and set gains graham Wanting to Buy (WTB) 3 04-17-2013 09:40 AM
has anybody ever testes setting gains with a DMM vs. Oscope? MERQUE General Car Audio Discussion & Questions 0 03-29-2011 08:10 PM
About to set my gains with a dmm 87linkin General Car Audio Discussion & Questions 22 07-08-2010 12:27 PM
How do I set my gains with a DMM? dbdragguy General Car Audio Discussion & Questions 78 07-03-2010 08:48 PM
