Remote turn on - Car Audio Classifieds!
Old 10-26-2013, 07:15 PM
0/11 ssssss857
Default Remote turn on
Wondering how everyone goes about wiring their remote wire on a several amp setup. I have piggybacked a dual amp setup but am going to be running 5 amps in this new build. Should I create a small distribution bar? Run it off a relay switch or piggyback all 5?
Thanks
Old 10-26-2013, 07:19 PM
serjr711's Avatar
0/11 sssss2699
Feedback Score: 65 reviews
I send the remote turn on signal to a relay, then use the 12v from the relay to turn on multiple amps, fans, etc...
Old 10-26-2013, 07:23 PM
0/11 ssssss857
What gauge wire do u have going into that relay and to that distribution block? Also did u run the relay right off the HU turn on lead?
Old 10-26-2013, 07:51 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
Use the remote wire off the H/U to switch the relay, then 14awg wire would be more than plenty big enough for the rest of the wiring.
Team CACO Team SHOK
Supporting Member
serjr711's Avatar
0/11 sssss2699
Replied to your pm.
Old 10-26-2013, 07:58 PM
0/11 ssssss857
Thank you guys. Just the typical automotive relay will work best?
Old 10-26-2013, 08:01 PM
serjr711's Avatar
0/11 sssss2699
Yep, I used a 30 amp Bosch relay.
Old 10-26-2013, 08:21 PM
serjr711's Avatar
0/11 sssss2699
You can buy it already made.
CE Auto Electric Supply - Turn-On Relay Kits
The Following User Says Thank You to serjr711 For This Useful Post:
ModFreak (10-26-2013)
Old 10-26-2013, 08:36 PM
92K1500's Avatar
3/17/2011 RIP
0/11 ssss22939
http://www.ebay.com/itm/RELAY-and-HA...dcfec4&vxp=mtr
Cheaper but doesn't have the inline fuse that you will want. You can probably get those cheap on ebay too.
Team CACO Team SHOK
Supporting Member
The Following User Says Thank You to 92K1500 For This Useful Post:
Old 10-27-2013, 07:42 PM
Team Ampere Audio
0/11 ssssss779
with the ground and power from the relay, can u just run it to one of your amps power and ground?? Or does it need to have a dedicated ground and power??
Im in the same situation as modfreak. running 5 amps and I don't have the neccassary equip. I wouild like to run a toggle to turn my amps on and off. how would I do thayt??
Team Ampere Audio
97 Cadillac Seville-6-Zv3 15"s-ported clamshell
Designed and Built-Neill Barber & Jimmy Rutherford
20k worth of Ampere Audio Amps
21-10" mids and 16-Supertweeters
25 Deka Group 31 batteries (2550ah total)
Remote amp turn on/power antenna turn on wiring issue. rstirm General Car Audio Discussion & Questions 2 05-04-2013 08:13 PM
HELP! Remote turn on dead. 350zkid General Car Audio Discussion & Questions 18 09-01-2012 09:58 PM
Help: SKAR 1500 amp won't turn on thru the remote lead Nori808 General Car Audio Discussion & Questions 22 03-26-2012 09:07 PM
How many units can be hooked up to H/U's remote turn-on lead? Vital General Car Audio Discussion & Questions 5 06-30-2011 01:20 PM
remote turn on ways of testing? splvictim20 General Car Audio Discussion & Questions 5 03-18-2010 11:20 AM
