What's your go-to box sealing product? - Car Audio Classifieds!
Old 10-27-2013, 11:24 AM
doug118's Avatar
0/11 sssss4674
Default What's your go-to box sealing product?
Just curious as to what you guys have had good experience with as far as sealing the corners of their boxes. I know fiberglass is best but what's everyones go to choice besides resin? I'm not looking to spend $45+ just to seal up the corners
In the past I've used DAP dynaflex sealant
DAP Dynaflex 230 10.1-oz. Premium Indoor/Outdoor Sealant-18275 at The Home Depot
Old 10-27-2013, 11:28 AM
0/11 ssssss767
Why not just use wood glue?
The Following User Says Thank You to 150orbetter For This Useful Post:
imlouder (10-27-2013)
Old 10-27-2013, 11:29 AM
doug118's Avatar
0/11 sssss4674
To be honest, I never really thought about putting wood glue in the corners
Old 10-27-2013, 11:35 AM
0/11 ssssss697
i use wood glue and after the pieces clamp together, I use the excess that squeezes out and I tool it into the seam.
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
I only use titebond II
I never use any other sealant aside from fiberglass from time to time but usually after it's all together ill run a bead along all edges with my finger
Old 10-27-2013, 11:38 AM
0/11 ssssss697
I use Titebond II as well, but actually just bought some titebond III yesterday to see if its any better. Good stuff
Old 10-27-2013, 11:40 AM
doug118's Avatar
0/11 sssss4674
I've only used Gorilla wood glue for the joints. Just bought 4 big bottles yesterday for my wall
Edit: After reading a few tests, I might return them and get TB3. I've never had an issue with Gorilla though so I'm not sure
Old 10-27-2013, 11:47 AM
0/11 ssss31258
most importantly... joints need glue where they meet. {not just on the outside}
my go-to's
#1) Elmers wood glue.
#2) titebond II
#3) 100% silicone
I used to like PL200 and 'liquid nails'.. but the company changed hands or something and they just aren't the same anymore.
Elmers and titebond are thin glue. (cuts need to be straight)
silicone is thick and easy... (cuts can be f'ed up) {but it stinks.. and it causes cancer in California}
I have painted elmers & titebond II on interior corners with a brush after assembling boxes with imperfect joints.. it works pretty well to seal it the rest off the way. {works like resin}
Old 10-27-2013, 11:51 AM
0/11 ssssss697
if you need to fill a small void from an imperfect cut, you could mix up some wood glue and saw dust and make a paste.. works great
The Following User Says Thank You to Jager For This Useful Post:
chefzane (10-27-2013)
Old 10-27-2013, 11:52 AM
doug118's Avatar
0/11 sssss4674
I just like to have the extra sealing factor of putting someone over the corners
Hatch not sealing right graham Sound Deadening & Fabrication 5 01-25-2015 09:25 AM
Sealing off help g6ryder General Car Audio Discussion & Questions 1 07-19-2011 09:30 PM
Sealing a wall??? cole20cole General Car Audio Discussion & Questions 19 04-23-2010 03:41 PM
sealing off trunk gbo559 General Car Audio Discussion & Questions 50 12-30-2009 10:21 PM
Sealing off the trunk? mazda6i07 Enclosure Discussion & Design Construction Help 51 10-23-2008 07:07 PM
