What wire to run?? - Car Audio Classifieds!
Old 10-28-2013, 09:04 AM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
Default What wire to run??
I'm doing a new build and need some suggestions, I'm gonna be running about 4k and I'm looking to buy some wire. Would a single run of sky high 2/0 ofc handle that load? It'll be wired at 1ohm so after rise it's pry making 2500-3k
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 10-28-2013, 09:07 AM
G00burr's Avatar
0/11 ssssss591
i would run big wire.<--- wire that is big
jk honestly i use wire from a welding supply shop. its always true gauge and cheap as ****
they will normally have 1/0, 2/0 and 3/0
Old 10-28-2013, 09:24 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
Alt output and battery situation is required to make this determination.
example, if you've got a 20ah batt under the hood and a 100a alt, but 300ah of batts in the back 1 run of 1/0 and a chassis ground would suffice. but if you've got a 100ah batt and 300a alt under the hood, with no batts in the back 5-6 runs of 1/0 front to back would be necissary.
Old 10-28-2013, 10:11 AM
0/11 sssss1813
Well I in my car now I have all stock wiring, I have a 50ah batt up front and a Xs power xp3000 in the rear and 1-1/0 run of cca knu, and a 1/0 ofc ground in the back, I have a stinger volt meter that reads volts at the amp and damn near full tilt it'll drop to 12.7ish, is there a need in my new car to run a run of 2/0 ofc sky high which is really like 4/0 or would a single run of there 1/0 do the trick? Trying not to spend a lot but want it right, and is really only like to run a single cable
4xSundown sa-8''s
Old 10-28-2013, 11:40 AM
0/11 sssss1813
Anybody? And does anyone know where to run wire on a 2004 grand am?
4xSundown sa-8''s
Old 10-28-2013, 12:59 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
The bigger, the better. I'd use the 1/0 wire for amps, same with to your alt/battery area.
Oh and OFC too. CCA, well there's a separate thread based on these two versions of wiring.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-28-2013, 01:02 PM
0/11 sssss1813
So is a run of 2/0 ofc sky high over kill? It'll run from front batt to the rear batt, then after that I'll use 1/0 to the amp, the amp will have 4 pos and 4 neg running into it
4xSundown sa-8''s
Old 10-28-2013, 01:17 PM
0/11 ssss12531
Nah...maybe a little but I'd rather have overkill than not enough.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-28-2013, 03:59 PM
G00burr's Avatar
0/11 ssssss591
If you can cram that 2/0 in your amp I say do it. The key is less resistance. Given that you have good electrical, 2/0 will allow for more current flow if you're pulling too much amperage for 1/0. I am running a 4k amp with 3 batts and 4 strands of 1/0 and it seems to do te trick though
Old 10-28-2013, 04:18 PM
0/11 sssss1813
I'm looking for the run from front batt to rear batt
4xSundown sa-8''s
WTB: 1 run of 1/0 wire Raptor660 Wanting to Buy (WTB) 12 09-16-2012 08:23 PM
Wire run question. David97 General Car Audio Discussion & Questions 8 03-16-2012 09:53 PM
WTB: run(s) of 1/0 wire uz1290 Wanting to Buy (WTB) 6 01-21-2012 10:06 AM
wire run Antstar24 General Car Audio Discussion & Questions 9 07-29-2009 08:45 AM
How to run wire from the battery Bologna General Car Audio Discussion & Questions 47 05-07-2009 11:01 PM
