Need a little alt help - Car Audio Classifieds!
Old 10-28-2013, 07:18 PM
beatnbronco's Avatar
0/11 sssss2284
Default Need a little alt help
I just installed my alts on my bronco, used a brand new tensioner my brother bought for his dakota and moved my idler pulley to allow for more belt to pulley contact. I started my truck up, everything looks great but there is a strange whine coming from my engine, my voltage will go up and down when the engine whine goes up and down. I need some pointers on what to check or what could be causing this because I'm drawing a blank...pls help
Old 10-29-2013, 10:03 AM
0/11 sssss2284
Okay..what would cause the voltage go up and down?
Sent from my SPH-L710 using Tapatalk
Old 10-29-2013, 10:04 AM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Bad regulator?
Old 10-29-2013, 10:15 AM
0/11 sssss2284
It wasn't doing this before I started the dual alt install. Only the master alt is being used, the slave is free spinning. I can swap out the regulators and try it
Old 10-29-2013, 11:27 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Bad ground maybe??
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-30-2013, 06:48 AM
0/11 sssss2284
Think I might have found the prob. I noticed that my slave alt and idler pulleys are moving just a tiny bit..that would cause the belt to tighten and loosen over and over causing the voltage to raise and lower at the same time. Lemme do some re-adjusting and bracing and see
Old 10-30-2013, 06:58 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
could be a bad alt or regulator, whine can indicate full fielding or a grounded stator lead.
is one of the alts getting significantly hotter than the other?
Old 10-30-2013, 07:11 AM
Veteran Member
0/11 sssss3026
a whine shouldn't indicate a belt slip, so your voltage fluctuation isn't a belt tension issue, imo.
whats your regulator situation?
Old 11-15-2013, 09:00 AM
0/11 sssss2284
Seems that by switching the location of the tensioner it allowed my belt to slip cuz it was no longer picking up the slack past the harmonic balancer.
Sent from my E270BSA using Tapatalk
Old 11-15-2013, 09:39 AM
dirt101's Avatar
0/11 ssssss956
so is it fixed? I just switched alternators in my blazer and I had to get a new pigtail and do some minor wiring coming off the plug on the alt. Stock had 1 wire in the plug but I needed two to get my alt functioning correctly. Before it would jump up and down in voltage from 13.6 to 14.05. Now its smooth at 14.35
DC Power Vortec V8 Dual Alt Bracket w/160 amp alt SundownSilverado Wiring, Electrical & Other Installation Equipment 5 07-13-2012 02:03 AM
mechman alt 200amp gmc tahoe yukon alt loudGMC Wiring, Electrical & Other Installation Equipment 12 05-08-2012 04:04 PM
Stock 140a Alt for GM 3800 Series II or a cheap HO alt Raptor660 Wanting to Buy (WTB) 10 04-08-2011 07:11 PM
dual alt bracket and ho alt for dodge magnum arntsmag General Car Audio Discussion & Questions 1 12-28-2009 12:17 PM
2nd HO ALT, worth it to ground alt case -> chassis? CleanNMean General Car Audio Discussion & Questions 0 11-13-2009 07:38 PM
