2011 focus wall help - Car Audio Classifieds!
Old 10-29-2013, 04:32 PM
0/11 ssssss197
Default 2011 focus wall help
52 width
37 height
25 depth
Thinking 4 18s what designs would you recommend flat wall? Clam shell?
Equipment 4 tantric hdd 18s
2 dc 3.5ks
Old 10-29-2013, 04:37 PM
0/11 ssssss579
Doesn't appear to be enough room for 4 18s to me.
Old 10-29-2013, 04:39 PM
0/11 ssssss197
27 cubes?
Old 10-29-2013, 04:45 PM
GPCustoms's Avatar
0/11 ssssss661
Originally Posted by joshy629 View Post
27 cubes?
That's a tight squeeze. you're gonna take up a lot with extra baffles and port displacement
Team Showtime Car Audio
Old 10-29-2013, 05:25 PM
mega fatty
0/11 sssss6008
if you do single baffle you could have 24cf sealed.
i would say minimum double baffle all around or be really good with bracing/building a shell.
double baffle your at 21cf
i would do 4 15's done and done.
double baffle all around, front baffle 4 layers thick, bracing and slot port on drivers side 7" wide 17" long.
Thats 17.5cf with 250ish" of port tuned to 35 and if you want to make the 17" port removable with only the 3" baffle in your tuning would be around 46hz.
and if you really wanted to get everything its got outa it, you could try shinking with 45's until you are happy.
07 mazdaspeed3
rd d9 @ .5ohm
Old 10-29-2013, 05:34 PM
xnewbx's Avatar
0/11 ssssss985
You will be happier with 4 15sand a well built box
doug118's Avatar
0/11 sssss4674
Try fitting 4 18's on a baffle that's 37x52 along with a port
Old 10-29-2013, 05:35 PM
0/11 ssssss197
What's Bout 15s in like a clam shell
Old 10-29-2013, 06:26 PM
0/11 ssssss741
you have no idea wth you want in that thing do you? id say go with the 15's but keep box size
Old 10-29-2013, 09:24 PM
mega fatty
0/11 sssss6008
Most 18's need 6cf at minimum
You have under 5 per
You could try 2 tantric 24's sealed
07 mazdaspeed3
rd d9 @ .5ohm
Emerald Coast Cruizin 2011 ~ Panama City Beach FL ~ 11-07-2011 CACO's Car Show Bot Car Show Feeds 0 10-30-2011 02:10 AM
2011 Street dB / Real SPL Regional Finals and IASCA 1x Bass Boxing 9/25/2011 Jeremy Weber General Car Audio Discussion & Questions 9 09-25-2011 11:48 PM
MCM Tour Round 1 / Draggin' Detroit 2011 ~ Taylor MI ~ 07-16-2011 CACO's Car Show Bot Car Show Feeds 0 07-16-2011 10:10 PM
MCM Tour Round 2 / Slam Jam 2011 ~ Mt. Clemens MI ~ 07-23-2011 CACO's Car Show Bot Car Show Feeds 0 07-16-2011 10:10 PM
USACi Sanctioned Event - Tex Mex 2011 ~ Sommerville TX ~ 04-16-2011 CACO's Car Show Bot Car Show Feeds 0 04-15-2011 10:00 AM
