Car Audio Gods Hate me...troubleshoot help... - Car Audio Classifieds!
Old 10-29-2013, 08:32 PM
0/11 ssssss546
Default Car Audio Gods Hate me...troubleshoot help...
I finally got everything working with my budget setup and everything sounded pretty darn good the past few weeks until I started having a strange problem. I don't even know where to start troubleshooting.
Everything was working as it should until the other day it seems some strange signals are being sent to my subwoofer. It is an intermittent problem and it comes and goes. It sounds like there is a low frequency popping or burping that happens. It will play for for a long time and only happen once or twice, it can be a pretty constant occurrence, or may not happen at all on a trip in the car. The signal is only being transmitted through the subwoofer as far as I can tell. The volume of the signal does not change things. It will happen with the volume on very low (but the popping will be at a much lower level). For example, I could be listening at a level of "1" and the popping will be very loud. If the music is loud, you might not even notice it if you aren't paying attention to it.
I know the sub can't play a signal it is not being sent, so the signal is coming from somewhere. Bad signal from the HU? Bad amp?
JVC DVD HU
MB Quart Onyx 600.4 amp
Pioneer Subwoofer
Edit:
I was playing with the RCA inputs and something odd happened.
My HU is a 5 channel so it is a single channel out to the sub. I put a Y-adapter off the sub channel and ran the RCA back to the amp. If I plug both RCAs in I get sound. If I only plug in Channel 3 (with either RCA lead) I get sound. If I only plug in channel 4 (with either RCA lead) I get no sound.
Could this be the problem? Channel 4 is not working?
Old 10-29-2013, 08:53 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Hmm...this one could be anything really. Bad RCA's, amp is starting to fail, make sure the bass boost on the amp is at 0, hu not functioning properly, loose wire/ connection somewhere...
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-29-2013, 09:14 PM
Turn it up's Avatar
0/11 sssss1933
where is your amp grounded?
Old 10-29-2013, 09:16 PM
0/11 sssss1475
I had something like this happen with a mtx amp years ago. Ended up being bad ground connections on the rca input. Temporary fix was to ground the input rca's to the output rca with speaker wire. Its crap shot but sounds kinda the same.
Old 10-29-2013, 09:36 PM
0/11 ssssss546
Found a bolt under the rear seat. I get over 14 volts at idle.
Old 10-29-2013, 09:40 PM
0/11 ssssss546
Thanks for the help so far. Its drivin me nuts!
Old 10-29-2013, 09:45 PM
lileddie1127's Avatar
0/11 sssss1225
Unplug RCA's from amp, turn volume up and see if that thump comes out your subs. If it come back it's your amp. Leave your speaker wires in, just unplug the RCA's. I had this happen to me a few years ago ended up being faulty amp.
6th order coming soon!
Team Juggernauts
The Following User Says Thank You to lileddie1127 For This Useful Post:
rxer311 (10-29-2013)
Old 10-29-2013, 09:46 PM
0/11 sssss1225
If it doesn't come back with RCA's unplugged, get a known good pair of RCA cables and swap them.
Team Juggernauts
Old 10-30-2013, 08:44 AM
0/11 ssssss546
Old 10-30-2013, 09:31 AM
Twitney181's Avatar
0/11 ssssss591
Same thing happened in my dads truck with his jvc deck, did that and it never happene again
Amplifier issue, help me troubleshoot Anton Miller General Car Audio Discussion & Questions 33 11-16-2013 04:36 PM
Deck/iPod troubleshoot. JuggaloRoso General Car Audio Discussion & Questions 6 09-24-2012 10:27 PM
Oh mighty audio gods of CACO TheJesus General Car Audio Discussion & Questions 7 05-03-2011 04:51 AM
I don't hate UPS, I hate stupid people! BlackWaterOp General Car Audio Discussion & Questions 30 02-27-2011 09:57 AM
why I hate audio korey_hofer Off Topic Chat 14 02-06-2010 09:48 PM
