Bizzarre bumping noise from subs - Car Audio Classifieds!
Old 10-30-2013, 09:21 AM
0/11 ssssss463
Default Bizzarre bumping noise from subs
This is weird. When I first start my truck and begin to drive, my subs will make a bumping noise for about 4-6 "notes" as i drive away. It stops and does not do it again until I shut it off and restart and drive again. Makes me believe it's linked to the ABS sensor in the truck.
Dual alts, 3 batts, sub amp grounded directly to battery (2' length only).
Ideas?
Old 10-30-2013, 09:22 AM
SPL Distribution Owner
0/11 sssss2983
These bumps could be the indication of bass!
But seriously, that sounds either like a bad ground or bad signal input.
Old 10-30-2013, 12:59 PM
0/11 ssssss463
It's grounded TO the battery 2 feet away. I'm gonna move it to frame and see what happens.
Old 10-30-2013, 01:13 PM
1/11 ssss31258
Seems you have an issue with your amplifier in the power supply section.
that is the sound of the amp 'powering up'... it's not supposed to do that.
it's likely to be a large capacitor which has the problem... but it could be a defective power supply transistor.
Old 10-30-2013, 01:17 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Some amps have a soft turn on/ turn off thump...but could be moderate or none at all.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-30-2013, 01:33 PM
0/11 ssssss463
If I start the truck and just idle, the amp is on and rockin. No thump until I roll out about 20 feet and It only Thumps 4-6 times and that's it. Amp jams full throttle all day.
Old 10-30-2013, 01:42 PM
Thelonewolf's Avatar
CACO SLACKER
0/11 ssssss597
bad connection of some sort could be rca could be ground or power.
Sub noise LivinLoud General Car Audio Discussion & Questions 9 07-09-2011 08:14 PM
noise and no bass from fresh reconed subs beatnbronco General Car Audio Discussion & Questions 14 08-12-2010 12:56 PM
Road noise in subs( not suppose to happen) quik6 General Car Audio Discussion & Questions 2 07-18-2010 01:23 PM
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 07:59 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
