Box Volume Effects on Equipment and Sound - Car Audio Classifieds!
Old 10-30-2013, 09:42 AM
tntahoe's Avatar
0/11 sssss1196
Default Box Volume Effects on Equipment and Sound
OK I was wondering what kind of effects box volume would have on a subwoofer and output. So a manufacture would suggest lets a minimum ported volume of 1.5cft and max of 2.5cft for the sake of argument the tuning will remain the same in every scenario. So if you made a box with volume of 1cft which is below the recommended specs, what effects would this have on output and the sub? Now lets say you made a box with volume of 3cft, what effects would this have? I already know that the smaller boxes will handle more power than the larger ones. Which scenario would give more output on the same power? Which setup would be safer on the woofer? Any info would be very helpful.
Old 10-30-2013, 10:11 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
I've wondered the same..
Sent From Oklahoma
Old 10-30-2013, 06:11 PM
tntahoe's Avatar
0/11 sssss1196
So no love for a pretty legit question.
Sent from my HTC One using Tapatalk 2
Old 10-30-2013, 06:20 PM
mega fatty
0/11 sssss6008
generally the larger the enclosure the more efficient it is. GENERALLY
so with 1000w it coul be louder then the 1cf enclosure with 1500w
when you have a smaller enclosure it will control the cone better so it may now need say 3000w to reach xmax when with the larger enclosure you could reach xmax with only 1500w
these are just examples. so the larger the enclosure the less effect the enclosure has on the cone. until you get to around 10xVAS which is considered infinite baffle and all the cone control is done by the subwoofers suspension.
1) efficiency
2) bandwidth
3) small space
Pick two
07 mazdaspeed3
rd d9 @ .5ohm
The Following 2 Users Say Thank You to tymoto21 For This Useful Post:
nobutada55 (10-30-2013), SINTORMAN (10-30-2013)
Old 10-31-2013, 04:52 PM
tntahoe's Avatar
0/11 sssss1196
So what gives the larger bandwidth?
Old 10-31-2013, 05:17 PM
mega fatty
0/11 sssss6008
a larger then normal enclosure will usually have greater efficiency (louder) and better bandwidth (play a wider range of frequencys)
but like many spl "burp" boxes, they are small and efficient, but they wont play from 20-80hz very well.
there are trade offs with every enclosure
07 mazdaspeed3
rd d9 @ .5ohm
Old 10-31-2013, 07:23 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
"Space makes bass"
Larger boxes are generally more efficient, have less rise have, better low end extension and are "flatter".
Smaller boxes can take more power, but that's because they're not as efficient. Small boxes can also be very peaky (not flat). The peaky part is why SPL boxes are so small.
Study the attached pic. See if you can guess which is a "properly" sized enclosure, which is the one that's small and which is the larger one.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 10-31-2013, 07:32 PM
tntahoe's Avatar
0/11 sssss1196
I assume the middle graph is what you want
Old 10-31-2013, 07:41 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Personally... I'd want the leftmost one. That's the box 50% larger than "recommended".
The middle one is optimum, the shallow response one is the 50% smaller than optimum. You can see the slight peak in the middle of its response. The smaller you go with that box, the more pronounced that peak will get.
At some point, you'll get too big and you'll lose control of the sub though. Basic models can only tell you so much. Some software can predict how much power a sub will take to reach xmax. That's useful to know depending on your setup and when you can get it to max output.
4x world champ
- Floyd E. Toole
Old 10-31-2013, 08:01 PM
tntahoe's Avatar
0/11 sssss1196
Yeah I have no clue how to tell when I sub reaches xmax and im sure I don't want to exceed it either. The graph looks like it is from winisd, which graph is that the gain or spl?
Effects of doing this to a box??? oxsign General Car Audio Discussion & Questions 31 09-29-2011 06:01 PM
"Sound waves' effects on hair" Hertz5400LincolnLS General Car Audio Discussion & Questions 9 08-17-2011 07:20 PM
box tuning and volume xmikedxl Enclosure Discussion & Design Construction Help 11 09-16-2010 11:00 PM
Box volume testing shizzzon (DC) 16 06-29-2010 09:10 PM
Box volume gbo559 General Car Audio Discussion & Questions 3 07-15-2009 03:51 PM
