Clipping a sub - Car Audio Classifieds!
Old 10-31-2013, 09:00 AM
0/11 sssssss24
Default Clipping a sub
Can clipping a sub cause a coil to be throwed of alignment, and create coil rub?
Old 10-31-2013, 09:10 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
1st of all, why r u clipping, if you are?
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 10-31-2013, 09:12 AM
0/11 sssss1475
Did it jump the gap n get stuck? That or over heat coil n started to unwind. Clipping just gets the coil and leads hot usually. Not building it right causes coil rub, not shimmed evenly or drop in was off center.
Old 10-31-2013, 09:15 AM
0/11 sssssss24
I bought a sub that was reconed 3 months ago from a guy on the Facebook classifieds. All my components I ordered finally came and we installed the system like last week. From the first time we powered the sub, we was hearing coil rub. I told the guy he sold be a damaged sub but he's tryna convince me that I clipped it. But I don't see how clipping a sub will throw it off alignment.
Old 10-31-2013, 09:23 AM
0/11 sssss1475
The coil being burnt/discolored, leads burnt, coil unwound... that's clipping indications. Coil rub is from dude reconing it and not doing it right.
Old 10-31-2013, 09:26 AM
0/11 sssssss24
My installer sent me a pic because he's gonna recone it for me. He said that it was clearly reconed wrong cause it was way off alignment. Coil has rub marks like crazy
SPL Distribution Owner
0/11 sssss2983
if what you heard was coil rub before it died then yes, clipping doesn't cause that.
Coil rub is not only caused from an improper recone either... however, from what you state, it sounds like an improper recone.
Another way this can happen is if the gap is very tiny and not intended to play music on it... but you do it anyways.
This will cause the former to rock ever so slightly causing it to hit the motor.
Old 10-31-2013, 09:27 AM
0/11 sssssss24
Is there anyway I can upload a pic from my iPhone. I'm a noob on the site, so I need a lil help.
0/11 sssss2983
you have to upload it to a hosting site first like photobucket then use their share links.
Old 10-31-2013, 09:28 AM
0/11 sssssss24
Thanks for the info, it's greatly appreciated
Clipping? Saginawbum1234 General Car Audio Discussion & Questions 8 01-05-2013 08:47 PM
Am I clipping my sub? carshateme General Car Audio Discussion & Questions 24 10-15-2012 06:36 PM
clipping? xnewbx General Car Audio Discussion & Questions 14 07-08-2012 11:28 AM
clipping zero1200d General Car Audio Discussion & Questions 4 08-09-2010 09:07 PM
What does clipping mean? ArcFault General Car Audio Discussion & Questions 20 06-06-2010 02:51 AM
