12s or 15s Maxima build - Car Audio Classifieds!
Old 11-01-2013, 11:14 PM
0/11 sssssss63
Default 12s or 15s Maxima build
I am thinking of switching up my build. I currently have 2 15s in a 2006 Nissan Maxima in a sealed box. I want to switch to a ported box. I know that the standard boxes that they had at the audio shop could not fit, so I may have to go custom to get that to work or just switch to 12s. I read somewhere that subs need "room to breath" and that too big of a box can have a "cork effect."
Do you think that I should try to seek a ported box for 15s that will fit/ have one built or switch to 12s? Ported box mainly couldn't fit because of width. The box was too long to turn when attempting to fit it into he trunk.
I must also add that I'm not into sound quality. I prefer the "boom." I like to see everything shaking hard and the trunk flexing. I'm not used to spacial issues at all. Going from a Navigator to a Maxima put me in this situation.
Old 11-02-2013, 02:29 AM
0/11 sssss5305
2 15's ported can be done, but you'll have to build the box inside the trunk and have very little room for amps and a few batts. Just depends upon how dedicated you are to the cause.
Otherwise 2 12's would be a LOT easier...
Old 11-02-2013, 06:46 AM
0/11 sssss1181
There is a guy around here that has a maxima with a 2 15' box built into the trunk with a trunk blow thru. Yes he is loud. When I had my civic before I walled it my best set up was 2 12's with the woofers firing up and a kerfed port to the rear. I did have 2 layers of deadener throughout the trunk
Old 11-02-2013, 09:49 PM
0/11 sssssss63
After considering the options looks like I'll have to go with either sealed 15s or ported 12s. I'll be using the same amp either way.
box build opinions for a 95 nissan maxima scoobdogg18 Enclosure Discussion & Design Construction Help 2 04-26-2012 04:53 PM
GoinDef's 2000 Nissan Maxima Build Log Goindef154 Build Logs 58 03-26-2012 06:16 PM
Old School Orion XTR Maxima build Goindef154 Build Logs 11 04-25-2011 09:58 PM
09 Maxima Build Ami Creations General Car Audio Discussion & Questions 15 06-24-2010 07:48 PM
gf's 96 maxima budget build newarkbeast973 Build Logs 17 09-22-2009 11:33 AM
