When to upgrade electrical system? - Car Audio Classifieds!
Old 11-03-2013, 07:03 AM
0/11 sssssss14
Default When to upgrade electrical system?
Hey all,
Pretty new to car audio, so I've got a question. As of now I'm running a Tru s45 in 3 channel with an SSLD6 to a pair of rainbow vanadium 230's and a boston g310-44 sub. I just don't have enough bass, and I'm looking to add another amp to power my sub. I'm a tru fan, and have been on the hunt for a hammer h-1. I've been looking at a lot of bigger amps, and they all require extra batts and power. I don't really want or need to get into that much of a system. My question is, when do I need to add another battery or upgrade my alternator? Will I need to if I can get a Hammer and run it at 2 ohms to my sub? Thanks for the help.
Old 11-03-2013, 08:10 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Big 3 upgrade to start, and a quality AGM battery under the hood and see how your voltage holds up.you may not need to upgrade your alt yet. the H-1 is a pretty efficient amp what is the stock alt amps?
Old 11-03-2013, 12:34 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
Stock alts aren't made to support much. I ran 800 watts on a stock electrical and had a lot of light dimming. Now I'm doing over 6k on stock alt but with an odyssey under the good and 4 odyssey group 31's in the back. I drop to about 12v full tilt but no dimming. Depending on your vehicle I don't see why a better alt can't be had for $300 or so. That would give you probably an extra 100-150 amps and that would allow for 12-1500 watts while never exceeding your alt amperage.
Old 11-03-2013, 12:52 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
When you replace your radio, think about your electrical. It's all down hill from there, you'll always want more
Stock electrical depends soley on the car, but I don't recommend anything more than 1k
Electrical upgrade KTMrida4life General Car Audio Discussion & Questions 5 03-04-2013 08:55 PM
next electrical upgrade tylork92 General Car Audio Discussion & Questions 1 11-21-2012 11:17 AM
How should i upgrade MY electrical system PureSound General Car Audio Discussion & Questions 17 08-04-2011 10:04 PM
Electrical Upgrade? ClevelandMFreeman General Car Audio Discussion & Questions 25 05-29-2011 12:17 AM
Electrical upgrade what to get first Xtremelegend General Car Audio Discussion & Questions 8 04-10-2011 03:50 PM
