DC Power Alt - Car Audio Classifieds!
Old 11-03-2013, 02:54 PM
AQTahoeZ71's Avatar
0/11 ssssss160
Default DC Power Alt
So I just installed a Used SPX300 alt on my 2004 Z71 Tahoe. When I started it up, The battery light on the dash was lit up and it said "Battery Not Charging" in the Digital Read out. But my Voltage Gauge is reading just over 14v. I know the stock Alt has 4 pins in the female harness and this DC one only has 3 but the Factory male harness only has 3 wires in it. Did I miss a step somewhere guys?
What could this be? Any ideas? Thanks.
'04 Tahoe Z71
18" AQ HDC3.0 (x2), MB Quart Discus 2000.1 (x2), Custom 3 Way Front Stage, PPI P900.4, DC Power Eng SPX300
Optima Red Top (x6)
Old 11-04-2013, 01:46 AM
0/11 sssss5305
On my grand voyager I had to wire in a resistor to trick the ECM into thinking there was an alt as it bypassed the factory set up. Sounds like you might have the same issue.
Give DC Power and call and let them know what's up...
Old 11-04-2013, 07:58 AM
AQTahoeZ71's Avatar
0/11 ssssss160
Thanks Mike. I think I got it figured out. Had to use an Adapter harness because the pin set up wasn't for my truck, even though DC said it was, lol.
'04 Tahoe Z71
Optima Red Top (x6)
DC Power 270 SP Alt truespartan9584 Wiring, Electrical & Other Installation Equipment 51 11-03-2012 04:50 PM
DC Power Vortec V8 Dual Alt Bracket w/160 amp alt SundownSilverado Wiring, Electrical & Other Installation Equipment 5 07-13-2012 02:03 AM
DC Power 270SP Alt. AQsrt4 Wiring, Electrical & Other Installation Equipment 8 05-16-2011 03:10 PM
How much power on stock alt? gbo559 General Car Audio Discussion & Questions 15 11-09-2009 10:10 AM
