DD Z1a manual help - Car Audio Classifieds!
Old 11-06-2013, 12:38 PM
0/11 ssssss271
Default DD Z1a manual help
I've been searching to web for the z1a manual but I've had no luck. Does anyone know where I can fnd the manual?
Old 11-06-2013, 12:43 PM
polys's Avatar
0/11 ssssss132
Default Z1a
you mean specs?
Series: Z
Input Sensitivity: 0.2V - 8V
Subsonic Filter: 10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter: 35 Hz - 250 Hz at 24dB/Oct
Clipping Display: LED
Model: Z1a
Tested Voltage: 14.4V
Tested THD: 1%
Damping Factor: >450 @ 1 ohm
Cont Power at 4 ohm: 1250W x 1ch
Cont Power at 1 ohm: 5000W x 1ch
Dynamic Power: 7072W x 1ch
Efficiency thru Output: >86%
Dimensions - inches: 27 L x 12 W x 2.76 H
Signal to Noise: 85 dB
Shipping Weight: 45 lbs
The Following User Says Thank You to polys For This Useful Post:
nateski10 (11-07-2013)
Old 11-06-2013, 01:39 PM
0/11 ssssss271
Originally Posted by polys View Post
you mean specs?
Series: Z
Model: Z1a
Tested THD: 1%
Yeah that works too. Thank you
Old 11-06-2013, 01:40 PM
polys's Avatar
0/11 ssssss132
you are welcome
Old 11-06-2013, 03:51 PM
Ali888's Avatar
0/11 ssssss674
Default DDz1a
I have marked it in red color,hope that works for you
Digital Designs.....GrounD PoundeR!!!
The Following User Says Thank You to Ali888 For This Useful Post:
C1100.4 Manual PapaGeno21 (Crescendo) 2 03-24-2013 09:47 PM
Manual for dd z1a. Kounelos General Car Audio Discussion & Questions 3 12-15-2011 02:56 AM
VCM Manual ddbump General Car Audio Discussion & Questions 0 08-18-2010 08:15 PM
Need someone that knows manual trans help themgators511 General Automotive Chat 15 08-01-2010 06:27 PM
